FYI, BOTH Fluke 289 and 189 have the same supercapacitor issue
I've cleaned these supercRapacitors up with IPA and check the board every few months
AFAICT they may leak and or or grow a brown beard or just go flat/short, just the one time
The meters still work perfect regardless, and the AA batteries do what the crummy internal stupidcapacitor should be doing,
keeping the current real world clock settings for logging etc during the brief period when changing the AA batteries
otherwise you just set the clock every time you change batteries, no big deal
It boggles the senses they did this same blunder TWICE on their flagship meter over a 15 (?) year span.
I suspect the 789 process meter may have the same issue too, and that's by no means a cheap DMM
I will eventually remove these supercraps and put in something reliable and long term
(ANY SUGGESTIONS ANYONE?) although FLUKE should be doing that SERVICE for me
proof of purchase or not in light of my ongoing support and partial recommendation for their very pricey wares
Then again.. if Fluke needs weeks/months to solder in one component, and replace it with the same problematic one
NO THANKS,
I'll roll with DIY and they can keep their Warranty and 'reputation driven company' BS for their fresh green customers
