Author Topic: Putty like terminal that lets you see values in hexadecimal  (Read 1668 times)
Offline Mr.D2Topic starter
« on: November 25, 2013, 09:15:40 pm »
So, in my project i need to test a rather complicated modem, and i'm trying to send commands using a USB-RS232 adapter linked to a TTL logic converter.
I need a program like putty that lets me send specific number in hexadecimal (because the alphabet of the target integrated circuit is different- GSM alphabet) and that lest me set the endianess and also receive the information and display in exadecimal... any pointers?
Best regards,
alm
  • Guest
Re: Putty like terminal that lets you see values in hexadecimal
« Reply #1 on: November 25, 2013, 09:23:57 pm »
RealTerm might work.
« Reply #2 on: November 25, 2013, 10:19:52 pm »
It works wonderfully, thank you so much.   :-+
Best regards
Offline enz
« Reply #3 on: November 25, 2013, 11:16:39 pm »
HTerm may also be worth a look:
http://www.der-hammer.info/terminal/
