Author Topic: Cal Test CT2700 40kV HV DMM Probe - Thoughts?  (Read 2402 times)
Offline reject902Topic starter
« on: March 24, 2016, 10:51:22 pm »
Hey everyone,
Was wondering if anyone here has ever used the Cal Test CT2700 40kV HV DMM Probe (link: http://www.tequipment.net/CalTestCT2700.html?search=true ) and/or what your thoughts of it were quality wise.
I'm picking up a HV probe for some CRT work, and the price on this probe is less than half that of it's well established Fluke counterpart. No reviews on TEquipment, but Amazon has 4 reviews, each 5 stars. It also includes the flat CRT tip for probing the anode, which makes it an even more convenient buy for me.
Since there's some serious voltages at play, I'm interested to hear any thoughts on quality before poking around with one of these.
Re: Cal Test CT2700 40kV HV DMM Probe - Thoughts?
« Reply #1 on: March 25, 2016, 03:20:52 am »
I'm picking up a HV probe for some CRT work......
CRO's or TV?
Avid Rabid Hobbyist
« Reply #2 on: March 25, 2016, 03:26:59 am »
CRO's or TV?
CRT monitors actually.
Offline AlienRelics
    • AE7HD
« Reply #3 on: March 06, 2018, 07:59:57 pm »
In two years, nobody?
I was considering this probe, too. Doing a variety of high voltage experiments. I have some older probes that have much lower input resistance.
Either this at 1G ohm, or I build one using a couple of 5G ohm resistors to get even higher resistance.
Steven J Greenfield AE7HD
Offline PartialDischarge
« Reply #4 on: March 06, 2018, 08:41:04 pm »
Well, be advised that the higher you go on the resistance the lower the bandwidth gets. And in this case it means that higher frequencies will show up as higher measured values not lower. It also depends if you can get along with a DMM probe or you need an oscilloscope probe
Offline nidlaX
« Reply #5 on: March 06, 2018, 08:58:45 pm »
This looks basically identical to the Pintek / Tenma, so I'm sure it's fine for the price and purpose it's designed for. Search HVP-40 for more info.
« Reply #6 on: March 06, 2018, 10:00:05 pm »
Yeah, it's a generic model # rebranded by a few.
Have a look at Pintek's site there's a few models to select from.
http://www.pintek.com.tw/
Last order from them I got a HVP-08 (8KV) for my own use and it HF compensates just fine on a 3V p-p 1 KHz probe comp signal.
Member Defpom had a look at it in this vid:
Avid Rabid Hobbyist
Offline AlienRelics
    • AE7HD
« Reply #7 on: April 19, 2018, 09:11:52 pm »
I have a 1000 to 1 scope probe, although I don't recall the maximum voltage on it.
For my purposes, I will be using this as an adapter for a DMM for DC and for 60Hz AC, so bandwidth shouldn't be an issue.
« Reply #8 on: April 19, 2018, 09:25:27 pm »
All scope probes come with a pamphlet, have you lost it ?
It will have the max voltage listed and more importantly a frequency derating curve.
The trap with a scope probe is the reference (gnd) lead doesn't provide the same operator safety as the probe itself  so use it with care and only connect the reference lead when the DUT is powered down/OFF.
Avid Rabid Hobbyist
Offline AlienRelics
    • AE7HD
« Reply #9 on: April 20, 2018, 06:44:05 pm »
Never had the manual for the scope probe. Bought it at a thrift store. I looked up the specs at one time, however I'm just on my lunch at work so I can't post the make and model right now.
Good tips about safety and high voltage.
