I recently scored a nice HP 431C power meter with cable and 8478B thermistor. (And also a 11527A adaptor, which is not required for this setup.)
I cleaned it, and seem to work fine, I can zero it, reads about right, but i have no idea how accurate it is. There is about 0.5 dB difference between the meter on my 8640B, and the power meter, but the signal gen's level meter is far from precision equipment.
The 431C was last calibrated some 20 years ago. The manual calls for the 8402B calibrator to calibrate it. Which is usually available on eBay, but would be uneconomical to get it because of the shipping cost. And that still doesn't calibrate the thermistor.
Anyway, do you have any idea on how I could calibrate or at least verify the accuracy of this meter? The sensor reads from 100MHz, so I can't just do an RMS measurement. Although, I do have a HP 3406A sampling voltmeter, which in theory can calibrate with its own calibrator, but that has not been calibrated for a long time, and I had to do repairs in it anyway. I do have 300MHz scope, but that is not precision equipment, either.
I don't have an other power meter or a calibrated power RF source.
