Well I tried going through the voltage calibration. I ended up using a battery and a 10 turn 1k pot, monitoring the voltage on the other side of a BNC tee connected to the input. It asks for -1.5V, +1.5V, -0.8V, +0.8V, -80mV, +80mV, -15mV and +15mV which I gave it each time. Unfortunately it fails, same issue the several times I tried, it says failed, calibration constants not updated, the error log says "Cal error. CVR source gain". Anyone know what this means? The self tests pass except for Calibration and the scope works but the calibration is clearly a bit off. The annoying thing is that it was working fine until I removed the DS1644 and read it to prevent calibration constants from being lost.
I'm thinking of trying to build a more proper voltage calibrator with a unity gain buffer on the output and a switch that I can just select each of the voltages it asks for. The lower source impedance would let me have the 50 ohm terminator it says to use in the manual, although I can't see what difference the terminator would make when calibrating DC.
