As these DMM models have logging & charting feature, with sample interval can be set from one second minimum to 100 minutes, and the logging session duration can be set from one minute up to 100 days.
The DC accuracy is 0.025%+2 digits at 5 Volt range with resolution at 0.0001V or 100nV 100uV.
Is it good enough to be used for measuring single cell battery noise ?
