Author Topic: Mastech MS8040 bench DMM back-light problem [solved]  (Read 3653 times)
Offline enut11Topic starter
  • Love building/modifying/restoring test equipment
« on: May 31, 2016, 11:21:39 am »
Hi. I have just purchased a Mastech MS8040 bench multimeter. It has 5 digits and good accuracy for the price (~$200AU). Sits on my bench and gets used most days.
The MS8040 has a large, easy to read LCD display with back-light capability.
My problem: the back-light has to be switched on manually and only stays on for less than 1 min, despite the unit being powered from 240vAC.
When I am taking lots of measurements, it is a pain to continually press the back-light button to read the display.
Any suggestions on how to modify the unit so that the back-light stays on permanently or at least 10 min or more?
enut11
« Last Edit: June 01, 2016, 11:10:25 pm by enut11 »
an electronics nut from wayback...
Offline tautech
Re: Mastech MS8040 bench DMM back-light problem
« Reply #1 on: May 31, 2016, 11:54:06 am »
If there's no menu option to permanently enable it a hack should be possible.
If it lights instantly with a push and hold of the button a bodge wire across the pads or terminals nearby should do the trick.
Have you tried multiple pushes to see if there's a lock on feature?
Avid Rabid Hobbyist
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #2 on: May 31, 2016, 12:35:11 pm »
Sometimes the controller IC expects to see a pulse from the switch, so simply making that line closed all the time with a wire might not work, you'll have to try it. It probably has an EL backlight so you might have to look at wiring that permanently to power.
« Reply #3 on: June 01, 2016, 06:03:20 am »
The yellow button toggles the back-light on and off. Holding the button on just makes the buzzer scream. Multiple pushes don't work either. :(
« Reply #4 on: June 01, 2016, 06:04:51 am »
What do you mean by EL?
Offline TheSteve
  • Living the Dream
« Reply #5 on: June 01, 2016, 06:54:17 am »
EL = electroluminescent panel.
VE7FM
Online xrunner
« Reply #6 on: June 01, 2016, 11:48:20 am »
That's what I thought was going to happen. It's under the control of a microcontroller or microprocessor. You'll need to hard-wire the back light to it's supply if possible.
The following users thanked this post: enut11
Re: Mastech MS8040 bench DMM back-light problem [solved]
« Reply #7 on: June 01, 2016, 12:39:40 pm »
Thanks All. I decided to hard wire the EL back-light panel so that it comes on with the main power switch. Works well.
The MS8040 back-light panel works off ~6 volts and draws ~60mA. The pins were marked A and K so I assumed a diode array. I disconnected the array from the main PCB.
I then wired an LM317 in constant current mode by soldering a 20 ohm 1/2W resistor between adjust and output pins. The input to the 317 was at the main filter cap (+25V).  The adj pin on the 317 was wired to the 'A' terminal on the back-light panel. The panel return 'K' was taken to a convenient earth point. Dissipation is about 1W in the 317.
enut11
« Last Edit: June 01, 2016, 12:41:19 pm by enut11 »
