Hi all,
I have a Rigol MSO11104z-s (with LA), but the flat cable to the digital test points is about 10cm shorter that I need it to be. I also have an old pod cable from a different Logic Analyser that would be long enough and the connector seems correct too. My question is: Are these interchangeable? Are they just glorified extension cables or do they contain active components matched to the device which would mean I can only use it on the device it was made for?
McBryce.
