Hi all
I am sure many of us have one of these cheap ebay transistor testers. They are basically all clones from
this original design. I bought
mine already a few years back, but I recently accidentally bought two more (I kept ordering
item A, they kept shipping me
item B, so I ended up with 2 partially refunded totally unneeded testers)
Of which I gifted one to my nephew who was building his own lamp dimmer. Turns out the tester is mislabeling the pins on TRIAC's
I tested TO92's small signal BT131-600 and MAX97A6, both of which are supposed to have the gate in the middle, but the tester showed A1-A2-G.
I also tested medium signal BT136-600, which tested as, depending how it was connected to what tester: a N-MOSFET; a SCR/Thyristor; a common-cathode-dual-diode.
The only hint something was wrong was that both FET and diode showed a rather high Vt of >4V. It seems testing for triacs is a bit tricky to get right.
(PS: diac testing shows "no device" but I guess the 30V threshold both ways makes that unavoidable. Like >9V zener diodes, I would not expect those ID'ed as well)
Anyway: out of interest, could other tester owners also check some triacs and see what you get.
Specifically, I am interested to know:
- If all cloned
2-line TXT models show the same erratic behavior on triacs.
- If the
newer graphics models (which I do not have) also show this behavior.
- If the
"brand" name devices (like Peak DCA55) deal better when identifying triacs.
Thanks
