Greetings all,
Recently, I've got a new task of designing an extremely low jitter pulse generator running at <1MHz speed. A sub-10-picosecond-jitter clock is required. Now the only device I have that can work in such a low jitter is a Tektronix 11801 with 4GHz sampling heads, which is a fragile piece of equipment and quite difficult to use for clock generation (by which I mean using the internal clock outputs as a clock reference).
The other clock sources I have are HP8656B and HP3314A. HP8656B has a jitter of over 100ps at a 100MHz output, which is unacceptable. I haven't tested the HP3314A. Since HP didn't even bother listing it in the specifications, I'd assume it's bad.
Any recommendation on buying or DIY-ing a low jitter clock?
