I picked up an 8050a of FleaBay for $35 shipped.
Upon arrival, the display wasn't working, but after letting it charge all night it came on the next day, but was displaying random stuff.
Before returning it, I thought I'd try new batteries, and that seems to have done the trick, but it still isn't perfect.
in the 200mv DC setting, I get a reading of about .01 mV with nothing being measured. At times this will drift up to about .10, but then comes back down. If I short the probes, it sites at .01mV.
Similar, shorting the probes on the 200 Ohms setting shows about .06 Ohms on the display.
Comparing measurements of voltage and resistance with my handheld Extech EX300 shows between a .2 to .4% difference in resistance measurements across various resistances. about .3% for DC Volts (testing some batteries), and 2.7% on AC volts (120V mains).
The offset doesn't bother me much, but the fact that the voltage drifts around makes me think somethings up.
For now, I plan to clean up the board with some contact cleaner and will plan to replace the PS Caps to see if that tightens things up a bit. From reading threads on this forum, that seems to be standard practice for these older units.
Hoping that addresses the issues. The buyer will take it back, but I suspect this is in fact 'in working order' as described and just needs some TLC.
Looking for any input from others on what to investigate or do while I have it opened up.
James
