Trying to build python control for Rigol DP832A PSU with x86 tablet running windows10.
(done before:
-got it working with Win7+NI-VISA+C#
-got it working on x86 tablet with Win10 +NI-VISA+pyvisa+python2)
Now my goal is to get it working by using opensource tools on Win10.
So far:
-clean Win10 installation
-installed python2-7.x
-cmd/ python -m pip install -U pip
-cmd/ pip install pyusb
-cmd/ pip install pyvisa
-cmd/ pip install pyvisa-py
Then python nagged about no backend... (python -m visa info)
so,I:
-installed usblib for DB800 via zadig GUI
I should now have all things in place.
did in python console:
>>> import visa
>>> resources = visa.ResourceManager('@py')
>>> print(resources.list_resources())
(u'USB0::6833::3601::DP8B185350299::0::INSTR',)
So far all works as expected, Rigol is seen on the USB connection.
But this fails:
>>> rigolpsu = resources.open_resource('USB0::6833::3601::DP8B185350299::0::INSTR')
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "C:\Python27\lib\site-packages\pyvisa\highlevel.py", line 1644, in open_resource
res.open(access_mode, open_timeout)
File "C:\Python27\lib\site-packages\pyvisa\resources\resource.py", line 203, in open
self.session, status = self._resource_manager.open_bare_resource(self._resource_name, access_mode, open_timeout)
File "C:\Python27\lib\site-packages\pyvisa\highlevel.py", line 1601, in open_bare_resource
return self.visalib.open(self.session, resource_name, access_mode, open_timeout)
File "C:\Python27\lib\site-packages\pyvisa-py\highlevel.py", line 191, in open
sess = cls(session, resource_name, parsed)
File "C:\Python27\lib\site-packages\pyvisa-py\sessions.py", line 184, in __init__
self.after_parsing()
File "C:\Python27\lib\site-packages\pyvisa-py\usb.py", line 176, in after_parsing
self.parsed.serial_number)
File "C:\Python27\lib\site-packages\pyvisa-py\protocols\usbtmc.py", line 236, in __init__
self.usb_dev.set_configuration()
File "C:\Python27\lib\site-packages\usb\core.py", line 869, in set_configuration
self._ctx.managed_set_configuration(self, configuration)
File "C:\Python27\lib\site-packages\usb\core.py", line 102, in wrapper
return f(self, *args, **kwargs)
File "C:\Python27\lib\site-packages\usb\core.py", line 148, in managed_set_configuration
self.backend.set_configuration(self.handle, cfg.bConfigurationValue)
File "C:\Python27\lib\site-packages\usb\backend\libusb0.py", line 493, in set_configuration
_check(_lib.usb_set_configuration(dev_handle, config_value))
File "C:\Python27\lib\site-packages\usb\backend\libusb0.py", line 431, in _check
raise USBError(errmsg, ret)
usb.core.USBError: [Errno None] libusb0-dll:err [set_configuration] could not set config 1: win error: The parameter is incorrect.
((my third day using python, so, sorry if it's something obvious...))
