Author Topic: Datron 4708 Possible board swapping with 4700, 4705 and 4707??  (Read 2351 times)
Offline acts238willyTopic starter
« on: February 07, 2018, 11:47:56 am »
The usual dilemma... an old machine with no available replacement boards.
My 4708 (AC only) has quit on me.
Will boards from the 47xx series swap with each other...
Or, do I need to use only 4708 boards to repair mine?
I also posted this in the metrology forum...
HELP!
Offline jfphp
Re: Datron 4708 Possible board swapping with 4700, 4705 and 4707??
« Reply #1 on: February 07, 2018, 06:22:41 pm »
You can swap most of the boards even with a 4200 (amplifier, synthesyzer...). Have a look at the part number of the boards. Options are coded in the CPU board and if there is no current, ohm... option you cannot put the option board into the slot occupied by a kind of dummy board.
The following users thanked this post: acts238willy
« Reply #2 on: February 07, 2018, 07:22:28 pm »
THANK YOU!!!
I was going to try to populate the 'AC only' 4708 with the DC and Ohms boards
(orange and blue tabs) from the other machine.
That would have driven me nuts!
WillyB
Offline jfphp
« Reply #3 on: February 08, 2018, 10:45:41 am »
If I remember but I don't know if it is indicated in the service manual, coding of the options is through dip switches. Have you got the op and the service manuals ?
« Reply #4 on: February 08, 2018, 02:16:52 pm »
The 4708 manual should have the codes, right?
I can't get to it right now...
Offline Samogon
« Reply #5 on: February 10, 2018, 02:34:07 pm »
here it is
« Reply #6 on: February 21, 2018, 02:50:17 pm »
Just went and looked at my 4708 AC option20 only....
All switches were DOWN?
And, it works fine, AC volts and current.
Switch levers 3 and 6 were marked with black pen,
as was the switch body above them??
Perhaps the board was harvested from a 10, 20, 30 machine?
Offline Samogon
« Reply #7 on: February 21, 2018, 02:54:28 pm »
All switches down meansyou have all boards installed and enabled
« Reply #8 on: February 21, 2018, 03:06:06 pm »
I just realized that the 'ohms' slot, the blue slot,
is filled with a half-card in the illustration.
Cards from the bottom are black, brown, red,
 orange (the DC board), yellow and green, the AC
boards..
blue, the current and ohms board, with the ohms
trimmer pots in the middle of a full-length card...
and violet, the power amp.
So, the illustration is an AC and DC machine, with NO ohms. (?)
