Author Topic: Default channel colour schemes for oscilloscopes  (Read 4522 times)
Offline Scratch.HTFTopic starter
« on: November 13, 2018, 01:31:19 am »
Out of curiosity, I did some analysis on default colours for oscilloscope channels (4 are assumed for the following unless noted):
LeCroy/Siglent: Yellow/Magenta/Cyan/Green
Tektronix/Hantek/Micsig/Atten/Tonghui/Rigol: Yellow/Cyan (Green in certain earlier Hantek)/Magenta (Green in certain earlier Hantek)/Green (Indigo in Rigol) - Atten and Tonghui currently do not manufacture units with more than two channels
HP/Agilent/Keysight: Yellow/Green/Blue/Magenta
Yokogawa: Yellow/Green/Magenta/Cyan
Uni-T: Cyan/Yellow/Green/Magenta
Owon: Red/Yellow/Magenta/Green
Pico: Blue/Red/Green/Yellow (and for 8 channel units, Purple/Grey/Cyan/Magenta)
Rohde & Schwarz: Yellow/Green/Orange/Purple
From this analysis, Tektronix is the most popular colour scheme - if not implemented, Sigrok should include presets for oscilloscope trace colour schemes corresponding to the manufacturers on this list (and others not listed here).
If it runs on Linux, there is some hackability in it.
The following users thanked this post: analogo, the Chris
Offline bugi
  • Hobbyist using the ultra slow and unsure method
Re: Default channel colour schemes for oscilloscopes
« Reply #1 on: November 13, 2018, 08:47:59 am »
Judging from that list, Pico and Owon haven't heard how common red-green color blindnesses are. Pico apparently goes with simplest possible way, "RGB", and the most common mixed color, yellow.  I wonder how good a choice the yellow / cyan pair is.
Offline Pinkus
« Reply #2 on: November 13, 2018, 08:56:53 am »
I am color blind, well not really 'blind' but having a red green weakness as many other men, I would like to see a scope where some can set his own colors for the four channels. e.g. I am not able to differentiate easily two traces in yellow and bright green on the screen. Thus I would love to make it a darker green for example.
The following users thanked this post: 001
Offline JPortici
« Reply #3 on: November 13, 2018, 09:23:47 am »
FWI all colors in the picoscope UI are customizable :)
Offline StillTrying
  • Country: Broken Britain
« Reply #4 on: November 13, 2018, 10:14:57 am »
The trace colours should all be changeable, or at least adjustable, I can't see dark blue on black.
Offline nctnico
« Reply #5 on: November 13, 2018, 10:57:34 am »
I agree. Actually I'd like to be able to change the entire color scheme. I very much prefer dark on light instead of the traditional light on dark. In the past I've upgraded several CRT instruments to LCD and in the process I altered the display data to have a dark on light color scheme.
The following users thanked this post: vk6zgo
Offline Hydron
« Reply #6 on: November 13, 2018, 12:50:14 pm »
Some of the newer scopes have RGB LED current-selected-channel indication for the shared vertical controls - this should make it easy to change trace colours while retaining the control scheme but needs buy-in from manufacturers.
It was specifically suggested/requested in the RTB2000 thread - this scope has _no_ permanent channel marker colours on the front panel that would contradict a change in software. While their firmware team has made other changes in response to user requests they haven't done anything on this subject.
The Tek MSO5/6 scopes seem to have some front-panel colour coding, but still would be able to match the LED indicator colour with a user set trace colour on the screen. I'm not as familiar with other scopes (the colour thing isn't really an issue for me), but it seems like something the manufacturers could do as a product differentiator (or just as a nice thing to help those with colour discrimination issues) without too much work.
Online Berni
  • Country: si
« Reply #7 on: November 13, 2018, 01:15:33 pm »
Yeah this should be customizable.
The only instrument i have that lets you change colors of not only traces but even other UI elements is my HP 89410A Vector Signal Analyzer. They simply give you a menu where you can select colors for each palette ID number. Internally they seam to be using a graphics card with 8bit pelleted graphics so this menu is simply adjusting the color lookup table for it.
As for what colors are best for traces is really debatable. I'm quite used to Keysight colors due to using there scopes the most. The more common Tek colors don't follow the rainbow so satisfyingly, but are admittedly the most functional since it puts Green and Yellow far apart. Those two colors are not only troubling for color blind but are harder to tell apart even for people with perfect vision when compared to all the other colors.
Offline james_s
« Reply #8 on: November 20, 2018, 05:48:27 am »
I know the colors are customizable in the Tek TDS700 series, I would assume that their later instruments retained this capability.
Offline vk6zgo
« Reply #9 on: November 20, 2018, 10:01:00 am »
Bah! Humbug!
Green was always good enough for me!
By the way,
Get off my lawn!
The following users thanked this post: Berni
Offline Mr Nutts
« Reply #10 on: November 20, 2018, 09:47:01 pm »
I can change the color of the trace and the overall color palette on my Lecroy Waverunner LT scopes, no problem  ;)
Offline Tom45
« Reply #11 on: November 20, 2018, 10:32:47 pm »
Bah! Humbug!
By the way,
Get off my lawn!
And if you don't like green, replace the CRT with one that has a different phosphor.
Offline james_s
« Reply #12 on: November 20, 2018, 11:38:13 pm »
That was a lot easier to do when CRTs were still being made. These days we're stuck with whatever people formerly purchased, and green was certainly the most common for scope CRTs.
Offline tautech
« Reply #13 on: June 01, 2021, 11:43:32 pm »
Stumbled here with a Google search for something else.  ::)
Firmware changes some months back for SDS5000X and SDS2000X Plus DSO's:
X and X-E models still only offer Yellow/Magenta/Cyan/Green
Avid Rabid Hobbyist
