Author Topic: DIY 10 MHz Distribution Amplifier - Requirements Gathering  (Read 25947 times)
Offline 4thDoctorWhoFan
Re: DIY 10 MHz Distribution Amplifier - Requirements Gathering
« Reply #50 on: May 19, 2018, 02:08:06 pm »
Has anyone tried powering additional circuitry, e.g. a GPSDO, from the existing power supply in the Extron 6 300MX?  I measure ~ 17.5V open circuit, 16V loaded by the distribution amp.  Would like to piggyback a TruePosition GPSDO board on the same rail if I can get away with it.
You probably should use a little separate  power supply.
Below are a few pix of mine.  I have a little 12V supply and the GPSDO mounted on the bottom plate.  I connected the 12V supply to the same AC input so it still only needs just the one AC input to power everything.
Of course, since it's a GPSDO, I drilled a hole for the Antenna input on the back.  Cut a rectangle on the front to insert the LCD display.
The first 3 rows of BNC's on the back are all for the 10Mhz.  The bottom row of BNC's are for the 1pps signal.
P1010139 (2)
P1010140 (2)
P1010142 (2)
P1010141 (2)
The following users thanked this post: Shock, mark03, klaus11, Jacon, jpwolfe31
