Products => Test Equipment => Topic started by: cidak on October 31, 2014, 10:45:44 pm
Title: DP811A ( DP800 ) SCPI Command Calibration for PC
Post by: cidak on October 31, 2014, 10:45:44 pm
Hi everyone, I'm the owner of DP811A, I installed the v1.11 firmware. I made the calibration of the V-DAC and the I-DAC output voltages and now all wrong. :-BROKE I tried for three days to redo the settings, to no avail. Then I read here on the forums that the 11.1 have a bug. Now I have an old iron box unusable paid 750 Euros. :palm:
Someone can 'help me to solve this problem?
I contacted RIGOL EU Engineer Mr Thomas told me that I should not touch the calibration and now so I have no warranty and I have to send them by paying the repair. :-- To me this does not seem fair, I did not do the problem, but they did their damage with a firmware bug. >:D
:-/O Someone SCPI commands for calibration, or any other solution to seat the power supply? :-DMM
THANKS! :)
Title: Re: DP811A ( DP800 ) SCPI Command Calibration for PC
Post by: TooOldForThis on December 02, 2014, 02:33:36 am
Hello cidak, Use the SCPI calibration instructions posted Here (https://www.eevblog.com/forum/testgear/rigol-dp832-firmware-updates-and-bug-list/msg556101)
They should work on the DP811A too. But the DP811A has different calibration points. Use the cal points in the document I attached.
Post by: TooOldForThis on December 02, 2014, 02:45:26 am
The DP811A can output 10.5Amps. So unless you have a real brute for a DMM, you'll have to measure the upper current ranges by measuring the voltage across a low impedance power resister attached between the + and - terminals.
Post by: cidak on December 14, 2014, 03:50:49 pm
:clap: Thank you very much for providing information on how to calibrate :bullshit: the DP811A Power Supplies.
