Author Topic: DP832 channel 1 UR  (Read 547 times)
Offline RustyCaliper
  • Country: gd
DP832 channel 1 UR
« on: February 05, 2018, 06:37:05 am »
Hi Forum,
I have an issue with my Rigol DP832. Something seems wrong with the current sensing on channel 1. It displays the mode as UR (unregulated) and shows an actual current of 0 A. Apparently it's a mechanical issue becuase the issue disappeared when I disassembled the unit, but unfortunately reappeared when I reassembled it. Knocking on the top board seemed to "fix" it. So likely bad connector/broken soldering joint.
However, I'm unable to locate the issue and I do not have any docs. I've done my RTFMing: http://www.eevblog.com/forum/testgear/dp832a-problem-ch1/msg424491/ and http://www.eevblog.com/forum/beginners/nonsense-behaviour-of-rigol-dp832/msg575509/ and http://www.eevblog.com/forum/testgear/another-issue-with-the-rigol-dp832-power-supply-sense-wires-carrying-3-amps!/ and http://www.eevblog.com/forum/testgear/what-is-actually-fixed-in-rigol-dp832(a)-rev3/ -- however no real leads.
My top board HW rev is DP832A V2.10 2013-03-26. Any help greatly appreciated.
Thanks, Rusty
Offline _Wim_
Re: DP832 channel 1 UR
« Reply #1 on: February 05, 2018, 08:14:10 am »
Does the output itself work correctly? Does the voltage measurement still work? If yes, I would expect it would be quite easy to follow the signal from the shunt resistors back to the ADC/Processor (not to many components in between I guess).
 I would also expect channel 1 and channel 2 to be fairly identical, so it should be possible to do a side by side comparison between the two when tracing back the signals.
Offline Pinkus
« Reply #2 on: February 05, 2018, 08:36:20 am »
I would open the cover and use a non conductive (e.g. plastic) stick to press on different PCB areas / components to narrow down the area. If it is a cold joint is is usually easy then to find the problem.
However if it is a broken trace with a micro crack on an inner layer it will become more difficult.
  • Country: gd
« Reply #3 on: February 06, 2018, 04:22:29 am »
Hey there, thanks for your suggestions. I believe the culprit in my case was J15, a two pin header that seems to feed the current sense resistor. It was optically *completely* inconspicuous, but since I've replaced it, it hasn't shown the error since. The contacts and everything looked completely pristine. Interesting...
All the best, Rusty
Offline _Wim_
« Reply #4 on: February 06, 2018, 04:01:17 pm »
All the best, Rusty
Glad to hear you could fix it, and thanks for reporting back what caused it.
