Author Topic: DS1000Z - How to get the full waveform memory?  (Read 841 times)
Offline jadew
« on: June 19, 2014, 02:20:06 pm »
Hey guys, any idea on how to get the entire waveform memory via SCPI?
I have tried :WAV:DATA? but regardless of the mode and state of the scope (stopped/running), I only get a small fraction of the buffer.
The datasheet says that if it's stopped and the :WAV:MODE is set to RAW, when you call :WAV:DATA? you would get the data that is in the big buffer and if it's not stopped, you get the screen memory.
