IIRC ATTEN / GRATTEN / SIGLENT [http://www.gratten.com.cn/ch/index.asp] was the sub-contractor for LeCroy (Teledyne)
WaveAve 100 family and in period 2010~2011 they screwed up with putting crippled DSO units on market ... - if you called the chief
sales of LeCroy europe - they would send you a patch disabling most of the unusable buttons on trigger menu - if you called them a second
time their nose was bleeding ... lots of people invested more than 1250 USD to throw their "trusted" unit in the garbage bin and
were forced to buy Agilent, Tektronix, LeCroy, Hameg R&S ...
Have a look to this video and enjoy:
"A donkey does not bump into the same stone twice." (?)
This video is from 2012. After then there have been several FW updates, and also HW updates. Siglent launched this scope March 2012.
This video is obsolete. Also I can not find information about freshly made selfcalibration. (Just this typical first use then read lesson number one style: "Brand new out of the box" - fun.)
Today things changes fast and of course most of manufacturers develop themselves more or less fast. Of course Siglent is also quite young manufacturer and have also made mistakes. Everyone do. They also have learned lot of. All signs show thet this company want learn.
Trigger level accuracy is not perfect. (and trigger is not take from digitized signal what level we know as ADC values are. There is DAC made analog level and comparator in principle and this singnal under test come from last input amplifier before adc. There is more or less inaccuracies in trigger voltage level and also time position. Take Rigol, Hantek, Owon, Tektronix etc in this oscilloscope class and there is this kind of problem more or less. Also inaccuracy may vary between single individual units. In these level scopes what use this kind of trigger circuit principle, this kind of problem is common and do not produce problems in normal use if user also know what he is doing.
It is totally different with more new trigger circuit principle. Some amount more advanced models today use digital trigger system. People who tell that this is "fail" do have total lack of knowledge and experience with this kind of equipments. What is normal and what is fail/error need also be in some relation to specifications (these are from Siglent. Not from Teledyne LeCroy).
Trigger system:
Trigger Level Accuracy (typical)
Internal? ±(0.2 div×V/div)( within±4 divisions from center of screen)
EXT? ±(6% of setting + 40 mV)
EXT/5? ±(6% of setting + 200 mV)
Trigger Sensitivity
For fixed gain ranges
1 Divisions: DC-10MHz
1.5 Divisions: 10MHz - Max BW
EXT: 200mVpp DC-10MHz,
300mVpp 10MHz - Max BW
EXT/5: 1Vpp DC-10MHz,
1.5Vpp 10MHz - Max BW
Vertical system:
DC Gain Accuracy
±3.0%: 5mv/div to 10V/div in Fixed Gain Ranges
±4.0%: 2mv/div Variable Gain Ranges
DC Measurement Accuracy:
All Gain settings?100mv/div
±[3%*(|reading|+|offset|) +1% *of |offset| +0.2div+2mv]
±[3%*(|reading|+|offset|)+1%* of |offset| +0.2div+100mv]
But, it looks like there is also real bug in this old FW (missing trace after trig). SDS1000CML/CNL/DL series was launched March 2012.
It need lot of knowledge and lot of experience to know what is normal and what is error or fail and also understand what are realities in different price classes. Example here need look both together, scope vertical trace position accuracy and Trigger level accuracy! In worst case other can be its positive error side and other can be its negative error side. Also it need have learn how to use Oscilloscope for best result with these realities what some oscilloscope have.
SDS1000 series CNL/CNL/DL models are cheap entry level scopes but in this Siglent price group they are ok.
Edit: Tried edit specs due to some special characters what this forum do not accept, still not good but it can find from siglent side, pdf.
