Some time ago I purchased an HP 8713B with no software options. I found information about reprogramming some bytes on the flash ROM to activate all software options and convert the 8711 to 8712 (VNA) and 8713 to 8714 (VNA):
https://www.eevblog.com/forum/testgear/enable-those-extra-features-on-your-hp-8714c-network-analyzer/The instructions are for the HP 871XC series and it works on the HP 871XB series except for IBASIC which requires a PAL chip (marked as U137 GAL16V8 on the CPU schematics).
So I had the 8713B converted to 8714B, but no IBASIC. So I started my quest to have IBASIC on my VNA. The other day I scored another HP 8714B that included the IBASIC U137 PAL chip. The PAL chip seems to have security bits programmed, and cannot be copied directly using miniPro. I connected my logic analyzer and I found out what the VNA expects as output of the PAL chip. It just wants the sequence of characters I B A S i C \0. The PAL (GAL16V8) chip defines pin 1 as clock and pin 11 as OE when operating in registered mode (flip flops), so I grabbed some old GAL16V8D, GAL16V8B and GAL16V8 chips on eBay and started to learn about PAL programming.
Using PALASM tool running on a DOSBOX image, I was able to recreate the state machine that HP used to generate the sequence "IBASiC". Before getting to the idea that was a state machine, started exploring the possibility of some crypto algorithm, but I noticed that it only had 9 clock transitions and 8 OE activations... impossible to implement any type of shift operation using only 9 clock transitions and generate 8 character sequence output, So it must be something very simple... like some basic logic mask using the input to generate the output. Reviewing the PALASM manual, I realized it must be a MOORE STATE MACHINE.
For anyone interested, I wrote the following state machine in PALASM:
; IBASIC PAL chip clone ;
;PALASM Design Description
;---------------------------------- Declaration Segment ------------
TITLE IBASIC
PATTERN A
REVISION 1.0
AUTHOR TK
COMPANY
DATE 07/05/17
CHIP IBASIC PAL16V8
;---------------------------------- PIN Declarations ---------------
PIN 1 CLOCK COMBINATORIAL ; INPUT
PIN 2 I0 COMBINATORIAL
PIN 3 I1 COMBINATORIAL
PIN 4 I2 COMBINATORIAL
PIN 5 I3 COMBINATORIAL
PIN 6 I4 COMBINATORIAL
PIN 7 I5 COMBINATORIAL
PIN 8 I6 COMBINATORIAL
PIN 9 I7 COMBINATORIAL
PIN 12 Q7 REGISTERED ; OUTPUT
PIN 13 Q6 REGISTERED ; OUTPUT
PIN 14 Q5 REGISTERED ; OUTPUT
PIN 15 Q4 REGISTERED ; OUTPUT
PIN 16 Q3 REGISTERED
PIN 17 Q2 REGISTERED
PIN 18 Q1 REGISTERED
PIN 19 Q0 REGISTERED
;-----------------------------------State Segment ------------------
STATE
MOORE_MACHINE
DEFAULT_BRANCH STATE0
;TRANSITION EQUATIONS------------------
STATE0 := S0S1 -> STATE1
STATE1 := S1S2 -> STATE2
STATE2 := S2S3 -> STATE3
STATE3 := S3S4 -> STATE4
STATE4 := S4S5 -> STATE5
STATE5 := S5S6 -> STATE6
STATE6 := S6S7 -> STATE7
STATE7 := S7S0 -> STATE0
STATE0 = Q7 * Q6 * Q5 * Q4 * Q3 * Q2 * Q1 * Q0
STATE1 = /Q7 * Q6 * /Q5 * /Q4 * Q3 * /Q2 * /Q1 * Q0
STATE2 = /Q7 * Q6 * /Q5 * /Q4 * /Q3 * /Q2 * Q1 * /Q0
STATE3 = /Q7 * Q6 * /Q5 * /Q4 * /Q3 * /Q2 * /Q1 * Q0
STATE4 = /Q7 * Q6 * /Q5 * Q4 * /Q3 * /Q2 * Q1 * Q0
STATE5 = /Q7 * Q6 * Q5 * /Q4 * Q3 * /Q2 * /Q1 * Q0
STATE6 = /Q7 * Q6 * /Q5 * /Q4 * /Q3 * /Q2 * Q1 * Q0
STATE7 = /Q7 * /Q6 * /Q5 * /Q4 * /Q3 * /Q2 * /Q1 * /Q0
CONDITIONS
S0S1 = /I7 * /I6 */I5 * I4 * I3 * /I2 * /I1 * I0
S1S2 = I7 * I6 * I5 * /I4 * I3 * I2 * I1 * /I0
S2S3 = /I7 * /I6 * /I5 * I4 * /I3 * /I2 * /I1 * /I0
S3S4 = I7 * I6 * I5 * /I4 * I3 * /I2 * /I1 * I0
S4S5 = /I7 * I6 * I5 * I4 * I3 * I2 * I1 * /I0
S5S6 = /I7 * I6 * /I5 * I4 * I3 * I2 * I1 * I0
S6S7 = I7 * I6 * /I5 * I4 * I3 * I2 * /I1 * I0
S7S0 = /I7 * /I6 * I5 * /I4 * /I3 * /I2 * I1 * I0
I used a GAL16V8 chip. Do not use GAL16V8D or GAL16V8B as they have active pull-ups on the I/O pins and when OE is HIGH, output is HIGH and not High-Z. The old GAL16V8 chip does not have active pull-ups.
PALASM takes the source code and generates a JED file that can be used with miniPro to program the GAL16V8 chip.
Now I have IBASIC and learned something about PAL and GAL programming
EDIT 19-MAY-2019: Attached IBASIC.JED.txt Download and rename as IBASIC.JED
