Author Topic: DS1054Z hack still good?  (Read 31874 times)
Offline worsthorseTopic starter
  • aina varma, usein väärin
« on: February 14, 2017, 01:10:03 am »
Good morning. Getting ready to buy a DS1054Z. Has anyone gotten the upgrade installed on the latest firmware version? Saw some posts that suggested it did not work. Also... can someone save me a couple of hours by pointing me toward the latest version of the hack?  Thanks!
Offline BloodyCactus
    • Kråketær
Re: DS1054Z hack still good?
« Reply #1 on: February 14, 2017, 02:21:49 am »
I mean, if your going to use the hack and save a couple of hundred dollars on options and bandwidth you could do a little research yourself maybe? Its not that hard to do a little reading on last couple of pages of the existant thread is it?
-- Aussie living in the USA --
Offline rstofer
« Reply #2 on: February 14, 2017, 02:37:43 am »
search for riglol including the misspelling here or on Google
remember, the option is DSER - nothing else.  Don't get creative!  Yes, I know DSER isn't a listed option.  Search for the term here on EEVblog
https://www.eevblog.com/forum/testgear/rigol-'unlock'-source-code-archive/
The following users thanked this post: worsthorse
« Reply #3 on: February 14, 2017, 03:55:03 am »
rstofer - thanks for the pointer. will do.
bloodycactus, i've done the research, including on this website. there is conflicting info. if you can't be helpful, why expend the energy needed to chastise me?
cheers - bill
Offline Dan Moos
« Reply #4 on: February 14, 2017, 04:18:19 am »
I agree, every thread on the matter is hard to wade through because of thread creep.
I searched YouTube instead. A few options, but one was the best by far (showed a clear screenshot of the website you need.)
Not sure what all the cloak and dagger is at this point. Fear that the rug will get pulled out I suppose, which I guess is reasonable. I have never found clear step by step directions on the matter here, just hints on how to google it. I'll play along, and just say if you search YouTube, the best tutorial is one of the top hits. There is one that gave an obsolete website, so just try another if you happen to go there first.
I got my 1054 a few days ago, and achieved your goal with no problems.
Hints I've gathered here:
When filling out the fields in the website that will not be mentioned here, erase the entire field (there will be stuff in it already, and even if parts of it are part of the stuff you want to enter, I've heard you still want clear each field entirely before typing in your info)
Follow the DSER advice. There will be a DSFR option that looks right, but it includes a feature your scope can't do in hardware. I  think its been shown to only be problematic if you try to use that feature, but rather than add the complication, use the DSER code. It won't be one of the choices shown, but it is the one you want.
Another possible point of confusion. I used my smart phone to do it, and when the window with the code popped up, the first batch of digits was only visible when I tilted the phone into landscape mode. Confused the crap out of me at first. I advise doing it on a PC to dodge any such confusion.
Good luck!
The following users thanked this post: worsthorse, Manuauto
« Reply #5 on: February 14, 2017, 05:46:06 am »
Thanks Dan... good to know that you accomplished the task with little problem. I did some more slogging through the threads here and tracked down the correct website (there seems to be more than one now, not sure that all are valid), along with the archived exe and bin files for local use. I did a test run of both the mac and windows versions and both seem to work. Because I am paranoid, I will run both versions of local (along with the website) and see if I get the same code before punching any numbers in. I just ordered my scope, so it will be a week or so before I can test. Will post results here.
Offline Chopsticks
« Reply #6 on: February 14, 2017, 06:12:57 am »
i just picked up a Ds1054Z a few days ago and i can confirm that using the riglol site and the 'DSER' option that everything works fine. like mentioned above dont use DSFR as this scope won't work with the '500uV Vertical' option.
DSFR enables everything including that 500uV Vertical option but the scope won't work properly with it (check other thread for details)
DSER will enable everything BUT the 500uV Vertical option so thats the option to choose
Offline Morty
« Reply #7 on: April 28, 2017, 10:57:29 am »
I picked up a DS1054Z today with 00.04.04.SP1 firmware and board version 0.1.4, I updated the firmware to 00.04.04.SP3 before using the DSER code, everything is working fine.
Edit: URL removed after reading Dans post, sorry if I broke any rules posting it.
« Last Edit: April 28, 2017, 11:29:38 am by Morty »
Online ebastler
« Reply #8 on: April 28, 2017, 12:51:55 pm »
I am not aware of any rules against posting a link to the "riglol" site; not sure where Dan got that impression.
Let me try, in the spirit of experimental verification:  ;)
http://gotroot.ca/rigol/riglol/
Offline mikeev
« Reply #9 on: June 17, 2017, 04:54:13 am »
hello,
I've got a DS1054Z.
Before upgrading the hack was working perfectly.
After upgrade to sofware version 00.04.04.SP3 (the latest version  availbable, it seems).
The hack does not work for me. Serial generated is unuseful.
Am I the only person who has the problem ?
Please help.
Board 0.1.4
Friendly greetings
Online ebastler
« Reply #10 on: June 17, 2017, 02:28:15 pm »
I've got a DS1054Z.
That is strange. In my experience, updating the firmware has always kept the previously enabled options intact. (Although I have not upgraded to the latest firmware yet.) There was no need to re-enter the option key. Did you do a factory reset before or after the upgrade, maybe?
Anyway, there have been quite a few reports about upgrade keys which did not work -- these issues were unrelated to firmware updates. The usual advice, which seems to have worked in all cases:
- Make sure you do not misspell any letters when entering the key.
- Refresh the RIGLOL web page and try to generate the key again.
- Try another browser and try to generate the key again.
- Download the executable for the key generator and run it locally.
Good luck! I am optimistic that one of the above will work for you as well.
Online Fungus
« Reply #11 on: June 17, 2017, 02:55:14 pm »
I've got a DS1054Z.
Yep. No need for new codes.
Offline mikeev
« Reply #12 on: June 17, 2017, 03:11:26 pm »
thanks for your answers.
What I did before the upgrade
:SYSTem:OPTion:UNINSTall
because I had activated previously the option not supported by the hardware.
Serial is generated using command line under linux.
I obtain the same serial using web page.
Trial is done.
Still no luck.
any more idea ?
Online ebastler
« Reply #13 on: June 17, 2017, 04:17:11 pm »
Trial is done.
Still no luck.
I think the most likely cause would be that you have either misread (or mistyped) the scope's serial number, or misread (or entered incorrectly) the generated option key. I don't recall ever reading about a case where the options were really no longer working.
The serial number is printed on the physical label on the back of the scope, too. Some characters can be hard to read in the small screen font.
To enter the option key, you can also use the telnet command :SYSTem:OPTion:INSTall, instead of the error-prone entry via the encoder knob.
Good luck!
Offline mikeev
« Reply #14 on: June 17, 2017, 04:30:08 pm »
Hello,
I've used the CLI to install serial.
All data are cut/paste from CLI (serial number, key).
No way.
I don't think I press the wrong keys.
Scope does not beep when I enter serial using CLI or control panel.
May I try downgrade scope to previous version of my firmware ?
When I put on a usb pen and old firmware from archive hxxp:--www.gotroot.ca-rigol-  I'm warned that is older.
But the Install option is still proposed.
I don't dare go further with the old firmwares from the archive.
I'm searching the previous version of my scope :
versions 00.04.04.sp1
Firmware_00.04.04.01.01
May be someone could share the file ? I can't find it.
I would be very kind.
Help is welcome.
Thanks to everyone on this forum which is just great !
Online ebastler
« Reply #15 on: June 17, 2017, 04:36:16 pm »
I have a copy of that file. Don't want to post it here, but if you PM me your email address, I'm happy to send it.
However, people have generally reported that the firmware loader refuses a downgrade. Worth a try anyway, I suppose.
Offline mikeev
« Reply #16 on: June 17, 2017, 04:43:23 pm »
MP sent
Offline mikeev
« Reply #17 on: June 17, 2017, 06:27:51 pm »
hi,
Thank you for firmware.
I could not downgrade.
The thing which suprises me is that when I enter the key code, I have no beep, or no box saying it is locked. Nothing happens.
Is it the same for everyone ?
Friendly greetings
Online Fungus
« Reply #18 on: June 17, 2017, 06:32:51 pm »
It's not possible to downgrade.
Do you have a beep or a box if you enter a garbage code?
« Last Edit: June 17, 2017, 06:34:36 pm by Fungus »
Offline mikeev
« Reply #19 on: June 17, 2017, 06:35:43 pm »
no. when  I enter code using CLI or control panel no bip, nothing happens when I validate.
The same thing happens if the code is good, or is not.
Online Fungus
« Reply #20 on: June 17, 2017, 08:01:34 pm »
Are you sure the codes are removed? (screenshot?) Try removing them again.
Did you do factory reset? (power off, press the magic button quickly after you power it on again).
If none of that works than I don't know what to do. You're the first person this happened to.
Offline mikeev
« Reply #21 on: June 18, 2017, 07:37:57 am »
here is what I"ve tried:
scope is powered on since more than 12 hours
1/ :SYSTem:OPTion:UNINSTall
scope beeps and display "Official options have been removed!"
2/ Power Off/Waiting/Power On
3/ Factory Reset
Display is in chineese
4/ Power off / Poweron
Select english, and activate sound
"Installed Options" displays for each line :
"version: trial, Left-Time: Trial Done"
5/ *IDN?
#RIGOL TECHNOLOGIES,DS1054Z,DS1ZAxxxxxxxxx,00.04.04.SP3
6/ Generate key using linux utility (cutting/paste serial number) using DSER
7/  entering cle (cutting:paste from 6)
:SYST:OPT:INST xxxxxx-xxxxxx-xxxxxx
no beep, nothing happens
still no options installed.
Even when I input garbage using control panel nothing happens.
Don't know what to do anymore.
greetings
Offline Andrew8086
« Reply #22 on: June 18, 2017, 08:00:34 am »
Please try this:
To install the 28-character key (4 groups of 7 chars but with no hyphens) use
    :SYSTem:OPTion:INSTall XXXXXXXXXXXXXXXXXXXXXXXXXXXX
    => If this doesn't work, enter key on device directly
Offline A Hellene
  • Country: gr
« Reply #23 on: June 18, 2017, 09:19:38 am »
I have just verified that the hack works fine (Board: v0.1.1) with the latest firmware (00.04.04.03.02).
Maybe you have downloaded a corrupted version of the KeyGen...
There is some experimantal information I have found out, additional to the already posted information at the hack thread:
--Binary value assigned to each letter:
A = 00000 | J = 01000 | S = 10000 | 2 = 11000
B = 00001 | K = 01001 | T = 10001 | 3 = 11001
C = 00010 | L = 01010 | U = 10010 | 4 = 11010
D = 00011 | M = 01011 | V = 10011 | 5 = 11011
E = 00100 | N = 01100 | W = 10100 | 6 = 11100
F = 00101 | P = 01101 | X = 10101 | 7 = 11101
G = 00110 | Q = 01110 | Y = 10110 | 8 = 11110
H = 00111 | R = 01111 | Z = 10111 | 9 = 11111
First character: D = official, V = trial
--Options:
DSAB (00011 10000 00000 00001): Official: Advanced Triggers
DSAC (00011 10000 00000 00010): Official: Decoders
DSAE (00011 10000 00000 00100): Official: 24M Memory
DSAJ (00011 10000 00000 01000): Official: Recorder
DSAS (00011 10000 00000 10000): Official: DG
DSBA (00011 10000 00001 00000): Official: 500uV Vertical
DSCA (00011 10000 00010 00000): Official: Power Analyser
DSEA (00011 10000 00100 00000): Official: Bandwidth 100 MHz
DSJA (00011 10000 01000 00000): Official: Bandwidth 70 MHz
DSSA (00011 10000 10000 00000): Official: Invalid / reserved license
DSH9 (00011 10000 00111 11111): Official: All options (-70M) <-- This is what I have installed!
DSR9 (00011 10000 01111 11111): Official: All options (+70M)
DS99 (00011 10000 11111 11111): Official: All options
VSAA (10011 10000 00000 00000): Trial:    +36 hours extension for all the options
--CMD:
:SYSTem:OPTion:INSTall <license>
:SYSTem:OPTion:INSTall xxxxxxxxxxxxxxxxxxxxxxxxxxxx (DSH9: All options except the 70M bandwidth)
By the way, the 500uV option works fine, even if it is really useless because that range comes from the (HMCAD1511: 8-bit, 30M..1GSa/s, 1x..50x Digital Gain, Multi-mode (Single-Dual-Quad) ADC) ADC chip internal digital gain feature, without really representing any useful data since the ENOB is decreased as digital gain is increased (according to the ADC data sheet, the 7.9 bits resolution at 1x gain (5mV range) goes down to 7.11 actual bits at 10x gain for the 0.5mV range)...
-George
« Last Edit: June 18, 2017, 09:48:03 am by A Hellene »
Hi! This is George; and I am three and a half years old!
(This was one of my latest realisations, now in my early fifties!...)
Online Fungus
« Reply #24 on: June 18, 2017, 10:10:20 am »
Don't put hyphens.
:SYST:OPT:INST xxxxxxxxxxxxxxxxxx
Offline mikeev
« Reply #25 on: June 18, 2017, 10:14:18 am »
yes ! Great ! Fantastic !
Using control panel nothing happens.
But without hyphen using CLI it does the job !
Thanks to everyone who helped and the others too !
I'm so happy !
Offline alsetalokin4017
« Reply #26 on: June 18, 2017, 10:25:44 am »
(OK good that you got it .. I just posted more instructions but they are not needed now.)
Online ebastler
« Reply #27 on: June 18, 2017, 10:43:50 am »
Hey, glad you got it to work!
It's still strange that entering the license key via the control panel did not work -- but I guess you are not in the mood now to experiment further and risk your options again. ;)  Enjoy your scope!
Offline mikeev
« Reply #28 on: June 18, 2017, 12:55:52 pm »
Hello,
Yes it is very strange that panel's input is ignored (good or wrong key).
But you're right, I prefer not changing anything, now that it works.
I'll upgrade the firmware if I meet a problem (this is rigol's recommandation).
thanks again.
have a nice day or night..
Offline forelle
  • Country: at
« Reply #29 on: July 10, 2017, 04:21:22 am »
Hi all,
I bought a Rigol DS1074Z some years ago and 3 days ago i thought i would like to make an uprade.First i put the latest Firmware on it.Then i reboot it and go to this site http://gotroot.ca/rigol/riglol/
I have deleted all characters write down my serial nummber and in Options DSER and press generate.I write down the code in the scope and i allways get as answer : invalid lisence.
I dont understand what mikeev has done that it now works.I am really bad with Pc and english is not my first language.Maybe somebody could explain me.Thanks.
Online ebastler
« Reply #30 on: July 10, 2017, 04:46:35 am »
I don't think you are experiencing the same problem which mikeev had. In Mike's case, it seems that he did not get any reply when entering a license code (whether a correct or incorrect one) via the scope's control panel.
If you are not so comfortable with computers, I would recommend that you retry entering the code via the control panel (rather than setting up an Ethernet or USB connection to send commands to the scope). Please review this post and try again: https://www.eevblog.com/forum/testgear/ds1054z-hack-still-good/msg1235820/#msg1235820
Good luck!
Offline forelle
  • Country: at
« Reply #31 on: July 10, 2017, 08:22:42 am »
Thanks,i will your recomendations.
Offline forelle
  • Country: at
« Reply #32 on: July 10, 2017, 06:57:10 pm »
Hi ebastler,
i have changed from Google Chrome to Mozilla Firefox and it works ;D,yeah.Thanks for this simple tip.
Have a nice day.
Online ebastler
« Reply #33 on: July 10, 2017, 08:04:45 pm »
 :-+    Glad you could fix it! Have fun with your upgraded scope!
Offline Zanatos
« Reply #34 on: July 13, 2017, 10:18:02 am »
Hello,
can someone confirm me that the last rigol DS1054Z's firmware is still hackable?
Is the 00.04.04.03.02 the lastest one, right?
I'm considering to buy this 'oscope.
Thanks!
Online Fungus
« Reply #35 on: July 13, 2017, 10:21:48 am »
a) It's not "hacking", it's just entering a license key, as designed.
b) Rigol sells these keys to people. They can't ever stop old ones from working.
« Last Edit: July 13, 2017, 10:24:04 am by Fungus »
Offline Zanatos
« Reply #36 on: July 13, 2017, 10:28:19 am »
a) It's not "hacking", it's a license key generator.
First of all thanks for your fast reply!!
Sorry if my questions are, maybe, trivial but this will be my first oscilloscope and i'm not so expert.
You are saying that, also with new firmwares, they can't prevent the ability to use old keys?
Thanks again for your help!
« Last Edit: July 13, 2017, 10:30:44 am by Zanatos »
Online Fungus
« Reply #37 on: July 13, 2017, 11:45:31 am »
Sure, I'm just trying to leave an answer in this thread that might stick.
Correct.
OK, it's not technically impossible, if they planned ahead, etc.
But ... hackers would just make a new keygen and it's 10000% more likely that their plan since day one is to allow keygens. It's good for sales.  :)
Offline Desserts
« Reply #38 on: August 02, 2017, 10:00:02 pm »
Hi folks - prepare for newbie questions... (sorry)
Just got DS1054z and I'm trying to learn about the upgrade "hack" but don't want to mess it up - so ask first (not my usual style - but I'm learning - slowly...)
Two questions -
First, I see folks listing firmware numbers as 4 or 5 groups of 2-digit numbers.  Mine just says "00.04.04.SP3".  Is this right or am I looking at the wrong thing?  If this is right (or at least usable), it also says I have board 0.1.4.  Big question - does anyone know if the "hack" for choice DSER works with this firmware and board?
Next, after I enter the generated key string (assuming it works), is there a way to "undo" the feature upgrades and return to the basic features the scope came with?
Also. if I enter a key string for a particular set of features (i.e., DSER), can I try a different set of features (i.e., DSFR) by just entering a different key string?  (Or do I first have to clear out everything and go back to the basic features it came with?)
I know this is a mess, but thank you in advance for your patience in wading through it.
Online MarkF
« Reply #39 on: August 02, 2017, 10:31:33 pm »
- The latest firmware version is 00.04.04.03.02 or 00.04.04.SP3.
      To see the full system info:
         - In the trigger area on the front panel, press MENU > MENU > FORCE > MENU     <<< press this sequence quickly
         - In the menu area, press UTILITY > SYSTEM > SYSTEM INFO
- DSER is all options. No need to try anything else.  DO NOT USE the DSFR option!
- To remove all options you must send the SCPI command :SYSTem:OPTion:UNINSTall via the USB or Network port.
   You can also add options by sending the SCPI command :SYSTem:OPTion:INSTall ‘license key’
« Last Edit: August 02, 2017, 10:36:08 pm by MarkF »
Online Fungus
« Reply #40 on: August 02, 2017, 10:35:52 pm »
Two questions -
Yes.
Yes.
DSER is the only one worth doing, DSFR is a bad idea, so...  :-//
Offline MattSR
« Reply #41 on: August 02, 2017, 10:41:12 pm »
Why is DSFR a bad thing?
Online MarkF
« Reply #42 on: August 02, 2017, 10:43:31 pm »
Short answer.  The hardware and calibration function do NOT support that vertical scale.
Online Fungus
« Reply #43 on: August 02, 2017, 10:43:42 pm »
Because the hardware doesn't support 500uV/div and you'll keep selecting it by accident every time you turn the knob in that direction.
DSER doesn't enable it.
The following users thanked this post: MattSR
Offline MattSR
« Reply #44 on: August 02, 2017, 11:38:37 pm »
...you'll keep selecting it by accident every time you turn the knob in that direction....
That sounds like good enough reason!  :-+
Offline Desserts
« Reply #45 on: August 03, 2017, 01:41:55 am »
Hi folks,
Thanks for the replies and explanations.   I appreciate the help.
I'm from the analog era (think: 545's and CA plugins) and my embedded biases on how things "should" work tend to make the learning curve a circle.  But I'll get there...
As soon as I'm comfortable with it's way of doing things, I'll do the upgrades.
Thanks again.
Frank
« Last Edit: August 03, 2017, 12:23:08 pm by Desserts »
Offline mathsquid
  • I like math.
« Reply #46 on: August 03, 2017, 11:18:34 pm »
When I look at the http://gotroot.ca/rigol/riglol/ site, I don't see DSER as an option. Does entering it anyway work, or should I use a different site?
DS1000z device options:
DSAB - Advanced Triggers
DSAC - Decoders
DSAE - 24M Memory
DSAJ - Recorder
DSBA - 500uV Vertical
DSEA - 100MHz
DSFR - all options
Online MarkF
« Reply #47 on: August 04, 2017, 01:16:44 am »
I echoed the bit assignments for each option in another thread, https://www.eevblog.com/forum/testgear/new-rigol-ds1054z-oscilloscope/msg752721/#msg752721, if you really want to know the details.  Just use DSER for all options.
Online Fungus
« Reply #48 on: August 04, 2017, 09:35:49 am »
Must resist urge to type something like: "We've created a global conspiracy and multiple threads on EEVBLOG telling people to use a bad code that makes their oscilloscope explode, and now you expect us to confess and change our story...?"
The following users thanked this post: tooki, nugglix, Jacon
Offline Tomer
  • Country: il
« Reply #49 on: January 05, 2018, 06:23:24 pm »
Just about to purchase the scope
Can anyone help me and confirm that the hack is still working ?
Thank you
Tom
Online ebastler
« Reply #50 on: January 05, 2018, 06:47:09 pm »
Yes.  :=\
Don't buy a "plus" model or an MSO though, those are much more difficult to "upgrade".
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
« Reply #51 on: January 05, 2018, 06:51:38 pm »
It has been and for ever will be a "hackable" scope since the flaw is in the implementation of the encryption - if Rigol wanted to fix that in firmware, they would have to also supply everyone who bought additional features at any point in time with new keys and I do not think they are willing to go through all this trouble.
Personally I would not want to be responsible for all the backlash this would cause.
He’s like a trained ape. Without the training.
Online Fungus
« Reply #52 on: January 05, 2018, 08:53:03 pm »
Yes.
The day it stops working you'll feel a huge disturbance in the force.
Offline ibendwires
« Reply #53 on: February 01, 2018, 11:55:19 pm »
(Adding another confirmation based on a recent purchase)
Just received my scope today  ;)  and was able to apply the hack with no problems. However, I used the wrong option (DSFR) instead of the (DSER). So I had to go through the process of removing all of the features via the SPI commands and reapplying with the correct information  |O
Anywho. Of note, my unit was up to date from the factory with the most recent firmware version 00.04.04 SP3 which meant I didn't have to upgrade at all. And from what I can tell thus far, this is an excellent scope for the price point. As I was currently using a Tektronix TDS1002B.
FWIW, The threads in these forums sold me on the unit  :-+
Offline Topher_duino
« Reply #54 on: March 07, 2018, 03:11:05 am »
I got my scope in today.  Also with the 00.04.04 SP3 software.
I almost cried when the first 3 attempts failed
Then I realised that I err'd on one of the serial numbers when reading it off the screen. doh! :palm:
After looking at the rear end of the scope, I was right as rain.
Good luck all.
Offline Bagpuss
« Reply #55 on: April 23, 2018, 09:51:40 am »
Just received my DS1054Z (with 00.04.04 SP3 software), but have a slightly different situation to most.
Mine already came from the supplier with all options enabled (except 100MHz).
This raises a some questions:
1) What would happen if I ran :SYSTem:OPTion:UNINSTall?
     Would this remove all of the options, regardless of the fact they were pre-installed at purchase?
2) How do I put them back? The company I purchased from didn't provide any serial key.
3) Given that I've got the options already, is there a different code I should use to enable just the 100MHz feature?
     I was thinking that using DSER would be correct, but just wanted to be sure.
Any help would be much appreciated.
Thanks,
Andy.
« Last Edit: April 23, 2018, 10:03:54 am by Bagpuss »
Online Fungus
« Reply #56 on: April 23, 2018, 10:30:09 am »
Yes.
Make your own keys with Riglol: http://gotroot.ca/rigol/riglol/
DSER will enable everything no matter what's already enabled.
Online ebastler
« Reply #57 on: April 23, 2018, 10:30:52 am »
I assume the options would indeed be removed. Pre-installation at purchase uses the same mechanism as a post-purchase addition, to my knowledge, and hence removal of options should also work the same.
Either ask the seller to provide you with the key, or use RIGLOL to generate your own (presumably identical) key. Or just don't uninstall the options; no need to do that.
I would leave the pre-installed options in place, and use DSEA to just add the 100 MHz bandwidth.
EDIT: Fungus beat me to it. ;)
No real difference between our two posts. Either DSER or DSEA should work to enable 100 MHz on top of your pre-installed options.
« Last Edit: April 23, 2018, 10:42:10 am by ebastler »
Offline Bagpuss
« Reply #58 on: April 23, 2018, 12:08:49 pm »
Thanks. Just used DSER to enable 100Mhz.  :)
Offline Old Printer
« Reply #59 on: April 24, 2018, 03:51:28 pm »
Bagpus,  If I might ask, why did your scope come with all of the options pre-installed? I am assuming, always a dangerous thing, that the upgrade promotion was only based around furnishing the keys (usually from the dealer by email). Did your dealer install them for you? If so then you surely want the legit factory supplied keys for possible future use. I am wondering if Rigol has started enabling the options from the factory since everyone has them anyway, which I doubt. Thanks.
Offline BravoV
  • +++ ATH1
« Reply #60 on: April 24, 2018, 04:43:04 pm »
For any legit and genuine Rigol certificate, you will be sent this, and use the key (the highlighted in red) to generate the real key at their web site to get the final key to be entered in the scope.
Example below here ...
Online Fungus
« Reply #61 on: April 24, 2018, 05:17:42 pm »
I wondered about that, too.
If you get the special deal you should receive an unopened box with the the 'scope inside and a separate certificate/coupon for your options. The dealer wouldn't pre-install the options for you because it's a lot of work for them, they'd have to unseal all the boxes, unpack the 'scopes and mess around with them entering keys.
So... what's the story? Did you receive your DS1054Z in a sealed box-within-box?
(Rigol puts two boxes on all their 'scopes)
Offline TheNewLab
« Reply #62 on: June 03, 2018, 07:09:25 pm »
My feeling is that Rigol is encouraging it, becausei nformation on how to do it is all over the Internet. It has been so for years. Rigol could have easily modified their software, at least to make it more difficult.
Why not encourage it? Just think of the overwhelming number of sales they are generating. They are making much more selling a large volume of units vs. trying to get people to pay the $100 or $200 for the extras.
 I would be really curious about how many units they sell an average year.
About dealers,(or sellers) doing the hack themselves. Except for the major distributors, it is a good way to get you to come back for future purchases. Once you get the rhythm, just get some person at minimum wage cracking away. If in China, labor is much less
Offline volbeast
« Reply #63 on: July 05, 2018, 09:53:54 pm »
I just upgraded my brand new DS1054Z today, the hack still works!
Offline rstofer
« Reply #64 on: July 05, 2018, 10:19:26 pm »
A couple of years ago I watched the inventory levels at Tequipment.  It appeared to me that they were selling about 1000 per week.  And that's just one supplier.
The new Siglents give them a run for the money but for awhile Rigol absolutely dominated the entry level scope market.  I really like my DS1054Z but I still want to buy the Siglent SDS1204X-E.  I'm kind of hanging back waiting on the firmware to get firm.  No hurry...
Offline TheNewLab
« Reply #65 on: July 06, 2018, 06:17:29 am »
Same here. the hacks on the Siglent so far are too technical to me. I would liek to learn to access code from a JTAG connector.
REgarding the Rigol. I just bought one. even with all the upgrades "official" I added the 100MHz upgrade with the suggusted code preference per these forum posts. worked fine. and did not lse the already installed upgrades.
Seller did not say anything about any included upgrades at all. just a base unit at a little over $200. hum.. maybe more. The box was still original manufacturer sealed. I think Rigol is just going ahead and including all upgrades except the 100MHz on these units now.
Online ebastler
« Reply #66 on: July 06, 2018, 06:36:18 am »
As mentioned in the other thread: no guesswork required, Rigol does indeed include all options for free.  Presumably "for a limited time only", but the offer has been standing for months now. See here for example, under "free software bundle":
https://www.tequipment.net/Rigol/DS1054Z/Digital-Oscilloscopes/
The price you mention seems too good to be true, however, options or not. Where did you get the DS1054Z for "a little over $200"?
Offline BravoV
  • +++ ATH1
« Reply #67 on: July 06, 2018, 06:43:08 am »
Dunno why have the feeling that DS-1054Z's successor is about to surface ?  :-//
Online Fungus
« Reply #68 on: July 06, 2018, 07:45:39 am »
And then all the new Siglent owners will cry out in pain!  :popcorn:
Offline OE2WHP
  • Country: at
« Reply #69 on: July 06, 2018, 09:28:04 am »
Most probably it "fell" from a truck....
Offline TheNewLab
« Reply #70 on: July 19, 2018, 02:29:50 am »
Ha! OE2WHP!! maybe you're right it was an Amazon delivery truck!! Tequipment was the source through Amazon. Amazon gave me a partial refund so and a quoted by net price - oops
It said nothing about any bundle, though. I had no idea until I went to another distributor who advertised a bundle but for around $500. I bought the thing..just so I could try out the hack. and had fun doing it, anxiety and all!
Fungus, not sure if Siglent owners will cry out in pain. their model has more standard features and a larger working screen. Now if they also drop their prices... or, drop the license and hardware add-on for the MSO..then we all will be crying out in pain.
Online Fungus
« Reply #71 on: July 19, 2018, 02:40:19 am »
We can unlock them for free.
We're speaking about the secret, unreleased Rigol model, right?
They must be due for a new one by now and we know they've been developing their own chipset for a while.
Offline shorelineproductions
« Reply #72 on: March 09, 2019, 11:55:43 am »
I wasn't aware of the DSER option at the time I hacked my DS1054Z.  Currently I have the 500uV vertical option enabled.  Is there a method to disable this option?
Online Fungus
« Reply #73 on: March 09, 2019, 12:46:08 pm »
a) telnet on port 5555
b) Type ":SYSTem:OPTion:UNINSTall"
c) :SYSTem:OPTion:INSTall XXXXXXXXXXXXXXXXXXXXXXXX
Where XXXXXXXXXXXXX is your DSER KEY
« Reply #74 on: March 09, 2019, 12:54:08 pm »
Thanks so much for the information, Fungus!
Offline reflowman
« Reply #75 on: May 01, 2019, 09:01:01 am »
FWIW:
26April19: Bought a DS1054Z (from Telonics - UK distributor for Rigol, £357.60 inc. tax+delivery).
s/w is: 00.04.04.SP4
board is: 0.1.4
All options included except 100MHz.
Downloaded and compiled http://gotroot.ca/rigol/riglol/riglol.zip.
Generated key for 100MHz code: DSEA
Worked fine.
Offline wasyoungonce
« Reply #76 on: May 03, 2019, 12:37:03 am »
Mine from Emona Australia came all options enabled by distributor.
~ Feb 19
board is: 0.1.4
I'd forget my Head if it wasn't screwed on!
Offline AlgisLt
  • Country: lt
    • asknotes
« Reply #77 on: June 12, 2019, 07:09:55 pm »
Just to report and confirm that for DS1054z, software 04.04.SP3, board 0.1.4, DSER options still can be successfully enabled  :-+
