Author Topic: DS1054Z front end switching noise?  (Read 1644 times)
Offline ice595
« on: January 16, 2016, 10:11:33 am »
So, I've got my Rigol DS1054Z a couple of days ago and hacked it to 100MHz.
As I was playing around with it, I discovered that the front end on all 4 channels seems to pick up a bit of noise.
I've disconnected all the probes and set coupling to GND and set 20MHz BW limit off.
it seems like channel 2 is "less" noisy that the others.
does anyone have this problem? ???
« Last Edit: January 16, 2016, 10:31:35 am by ice595 »
Offline TheSteve
  • GHz or bust
Re: DS1054Z front end switching noise?
« Reply #1 on: January 16, 2016, 10:29:11 am »
Its normal. The Rigol DS1054Z isn't perfect, but it was cheap...
VE7FM
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: January 21, 2016, 01:10:15 am »
my ds1054z arrived today... fresh unmodded 50MHz with limitation...
1st pic: before cal
2nd pic: after cal
same setting as OP... (except 2nd pic i forgot to reset to 1X)
« Last Edit: January 21, 2016, 01:11:58 am by Mechatrommer »
if something can select, how cant it be intelligent? if something is intelligent, how cant it exist?
Moving Forward to the Future, Breaking the GHz Barrier... (DDA5005)
