I have a E3634A which I suspect uses the same display? The unit I have is not working and I have given up trying to repair it (
https://www.eevblog.com/forum/repair/agilent-e3634a-fails-with-error-718/).
I would be very happy to give you the entire unit as I have learned a lot from your channel and I have failed fixing it - perhaps there is some other common bits that could come handy to you?
If you happen to have something surplus to you that you would be willing to give me in return I would appreciate, but if not I would be perfectly happy still. As said, I have watched a lot of your videos and learned a lot from it.
I have a schedule trip to the US in the coming weeks which means I could take the unit with me and ship it from Houston (where I will be).
When I get home I will try to make sure the display is indeed the same.
