So I know you can use some 50ohm resistors and caps with coax to make a 1x probe, I also know this technique will load your circuit and draw alot of current.
Some american companies offer 1x probes at 25mhz bandwidth, I.E Probemaster and Avex. I bought the Avex 100mhz monolithic probes, now im lookin for a good way to do 1x, what is it these 1x probes do over coax? Do they still load your circuit, like coax?
