Author Topic: DS1074Z - Decode RS232 ASCII problem  (Read 1578 times)
Offline matkar
  • Country: si
  • Sixty percent of the time it works EVERY time.
« on: October 10, 2015, 08:46:06 pm »
I've found a problem with the decoder. When decoding character "8" it actually displays "9" when in ASC mode. Other modes (HEX, BIN, DEC) return the correct value.
I've tested on 38400, 8N1.
I have the original firmware it came with the scope: 00.02.01.SP1
Is this a known issue? Has it been resolved in newer firmware updates?
Offline Karel
Re: DS1074Z - Decode RS232 ASCII problem
« Reply #1 on: October 10, 2015, 10:34:34 pm »
No problem here, running latest fw 00.04.03.SP1.
The difference between theory and practice is less in theory than
the difference between theory and practice in practice.
Expensive tools cannot compensate for lack of experience.
Offline matkar
  • Country: si
« Reply #2 on: October 11, 2015, 08:12:13 am »
Thank you Karel.
Obviously it's time for an update...
Offline H.O
« Reply #3 on: October 11, 2015, 07:13:00 pm »
Have you tried all other characters and is it only '8' that's wrong?
I'm thinking perhaps your actual baudrate doesn't match what the scope is set to so it misinterprets.
I don't have a DS1054Z myself, just thinking out loud....
Offline smithnerd
« Reply #4 on: October 11, 2015, 11:00:30 pm »
This bug was fixed in version: 00.04.02.03.00.
"4. RS232 decoder shows ‘9’ for ‘8’ input in ASCII format."
(According to the firmware release notes).
