Hi Everyone,
I've been playing around with the ultra station software (it is NOT impressive). If I make a new file for DS1074Z-S and set it to the maximum speed (10MHz), it will let me freehand a waveform. I saved it to a RAF file which if I am understanding right, is the same thing as an ARB file and can be loaded on the scope.
My first question is, can it really play 16384 points at 10Mhz? It suggests that this is the case when I right click and switch from points (showing 16384) to time showing 99.994n. If this is true, HOW does it accomplish this?
Second, can someone make a sample small number of points ARB file and post it. The file is a raw 16K file storing 16 bit integers. I wonder if you only put say 4 points in, does it will 4K with point 0, 4K with point 1, 4K with point 2, and finally 4K with point 3?
Thanks!
