I am digging into the HMO manuals (HMO3000 series, HMO Series 72x...202x) and there is something I don't really understand. Under the "Documentation, Storage and Recall" part:
"10 .3 Curves In addition to references, you can also store A/D converter data. A maximum of 24,000 measured samples (expanded display memory) can be stored on a USB stick. Curves can only be stored to externally connected USB sticks (not internally).
The maximum of 24,000 measured value points can only be read out with the maximum sampling rate (ACQUIRE menu). For the AUTOMATIC setting (repeat rate), the maximum amount of measured value points is limited to 6,000 (default setting)."
Does it mean that only 24000 points of data can be saved only from the 2 MPts of memory? Or with the mentioned reference data, is it possible to save the full memory? If so, what is the saving Traces/Curves for?
