Author Topic: DSA815-TG Internal battery  (Read 836 times)
Offline Pirapoense
  • Country: br
« on: July 15, 2017, 01:43:18 am »
I have a Rigol DAS815-Tg which presents an interesting anomaly in the date and time displayed on the screen.
It is normal that we have to set the date and time when turn on the equipment for the first time like when I bought the equipment one and half year ago; however, when the power is turned on for a new use, the date and time remains in the status of the moment that the power was turned off.
Obviously I thought that this anomaly was caused by the discharged internal  battery but the problem persists even with a new battery.
Any suggestions on this issue will be very welcome.
Offline mcinque
  • I know one thing: that I know nothing
Re: DSA815-TG Internal battery
« Reply #1 on: July 15, 2017, 04:49:48 am »
maybe RTC dead on arrival?
I'm basically still a rookie and because of this, even with the best intentions, I often say bullshits
Offline Pirapoense
  • Country: br
« Reply #2 on: July 15, 2017, 05:54:41 am »
It could be but the clock runs while the equipment is turned on.
Offline mcinque
« Reply #3 on: July 15, 2017, 06:01:22 am »
Yes, I think it's more the RTC clock powered by the internal battery that is somewhat defective and won't run with battery power. Can you measure the current drain for the battery (too see if it's powering effectively something or if it's floating or if it's shorted and drained quickly)? I'm just guessing
