I find that most companies don't do a good job of listening unless you are their bread and butter...
Unless you have a dialogue with someone that has good contact with a manufacturer, well what do you expect ?
Seriously, tell us what you want/need in a DSO UI and there will be a DSO that's very close to your requirements.
tautech, I wish I could in quantitative ways... my intention here was to have a dialogue based on some observations of things I've seen painful in a singular device. Over my years I've come to realize that knowledge can be gained the hard way through time/trial/experience (and that is the best form of KNOWledge), but it can also come from the advice and experience of others. In this scenario, I simply desired inputs from others on their definition of "good interface".
I'm a noob here that's gone from an old analogue scope and a couple of cheap handheld DMMs to a reasonably well outfitted "lab" in a short period of time. My equipment greatly exceeds my knowledge and experience.... Working on a repair, I realized quickly that the Rigol interface was more about rote memorization than intuitive interactions.
* Little things, like the turning of the knob to control selection when multiple items are presented on the screen is completely backwards from my intuition; my brain says "clockwise should go down", but instead the selection moves up.
* Selecting measurements using the left most buttons requires going to the "Measure" menu where you can get rid of measurements visually by going to the 3rd menu down, choosing "select item", then toggling them off,
* However, as soon as you add another one, the one you toggled off re-appears....
* To actually remove it you have to go to Measure->Clear->Delete.. but that doesn't really delete it, it just greys it out on the screen(!@!@#!). ]
* Choosing "Delete all", actually deletes them all... until you add another measurement, then 4 greyed out ones appear and the one you added appears on the right...
* .. So if your first 3 measurements were channel 2, you no longer need channel 2, you delete them, turn off channel 2 and add a channel 1 measurement, 3 greyed out measurements appear followed by channel 1.
My intention isn't to just complain... functionally it's a great unit for the price point. I just wonder if there is another price point where these front-and-center niggles don't exist.
With any bit of technology, my preferred interface is simply one that doesn't get in the way of stream of consciousness.
</rambling....>
-j
