Hi Everyone,
as my first post, let me tell you a short story about something which should be a no-brainer. So I bought this multimeter off eBay for a reasonable price. Brand new they go for ~€220, used around €150, I bought it for €90
http://goo.gl/zr5w7A - neat, huh?
The guy didn't specify anything, just 'good condition, see picture'. Now, having held this in my hand, you probably wouldn't see a ding if you ran it over with a car, but I didn't know that before.
One problem: it shuts itself off in about a minute after power-on. Batteries, right?
Uh-oh. Now, If you don't know why this is bad: first of all this means the owner didn't take care of it, so he might neglected it in other ways. Second, this not only means replacing a battery holder - leaked battery acid can travel over wires (capillary effect) and actually damage the PCB on the other end! As you can see on the picture, I cut the holder off, and stripped the negative wire, the copper strands are already discolored. Crap.
Now, this is a _really_ well built instrument. How far along do you have to strip it to get to the two solder joints on the board?
Just this far. That's the bare naked LCD sitting on top of its holder in the upper left. I marked the connector 'TOP' on the top side, for my peace of mind.
Sorry my phone froze on the picture in which the board still had the wires, but you could see a greenish crystally spot around the negative wire, about 3mm in diameter. I cleaned it up with alcohol. I'm not really a chemist, so I'm not sure if this is enough to deactivate the acid, I hope it is.
Back together. It seems it skirted the death-by-battery-acid and also the forgot-to-attach-esd-strap-at-first events. Btw, that battery should be over 4.5V
