The 174 is about as big as the 83 and 87. I just want to know out of the 3 which two would allow me to handle electronics work and be benificial in my EE program. I cant find alot of info on the 174 other than it was a limited run and sold for 99 dollars. I am curious about its reliability but I guess its to soon to know that.
The 174 looks like a capable and durable meter with IP54 protection. I saw the deal for $99, seems like a great bargain. You don't need to worry too much about the reliability of these meters, they're all fairly robust. Unless you're deliberately running them into the ground like joeqsmith, they should last you a while. Even if you end up damaging them, they're well designed, safe, and repairable.
I recommend selling the 83V because I think you can put the money to use buying other instruments that will help you as a student or hobbyist. If you're unfamiliar, take a look at the spec sheet for the 174. As far as I can tell, the
174 meets or exceeds the 83V in all categories.
EDIT: Actually, I forgot the 174 doesn't have a 10 Amp range and a bar graph. I guess there are some trade-offs, but if anything I would still sell the 83V and get a BM235 or BM257s in its place.
