Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
EEVblog 121GW Disassembly?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: EEVblog 121GW Disassembly? (Read 1582 times)
ANTALIFE
Frequent Contributor
Country:
( ͡° ͜ʖ ͡°)
on:
January 09, 2018, 08:40:52 am »
How on earth do you remove the little brass insert?
Logged
https://www.antalife.com/
andtfoot
Supporter
Country:
Re: EEVblog 121GW Disassembly?
Reply #1 on:
January 09, 2018, 10:32:34 am »
There's a circlip style thingie (e ring/clip) behind the circuit board that keeps it retained on the front housing.
Logged
ANTALIFE
EEVblog
Administrator
Country:
Reply #2 on:
January 09, 2018, 10:52:23 am »
Once you undo the screws holding down the PCB, the PCB should just lift out (may need a bit of a lever) leaving the brass insert behind in the case.
You do NOT have to remove the plastic clip in order to get the PCB out of the case.
Logged
ANTALIFE
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
