Poll
Should I Crowd Fund The BM235?
Yes
34 (19.2%)
No
143 (80.8%)
Total Members Voted: 171
Author Topic: EEVBlog BM235 Multimeter Dilemma  (Read 75656 times)
Offline Towger
  • Country: ie
Re: EEVBlog BM235 Multimeter Dilemma
« Reply #175 on: May 25, 2016, 12:13:51 pm »
Dave,
Have you tested the maximum voltage is can read or withstand?
The specifications say 1000 V DC.  It will happy read over 1000 V, so there appears to no hard limit in the firmware.  My 87 Fluke displays OL at  1000 V.  Unfortunately (or fortunately!) I don't have the capability to test it at more than 1070 V. Is 1100V a limit some cheap meters have?
Can it be pushed up to 6000V before the magic happens :-)
« Last Edit: May 25, 2016, 12:16:52 pm by Towger »
Offline dave_
« Reply #176 on: May 26, 2016, 08:47:12 am »
Just used my EEVblog BM235's temperate probe to record a fever of 39.3c. Such a versatile unit! :p
Indeed, I used mind to calibrate my daughter's thermometer:
Maybe I'm missing the joke here, but is that not a terrible idea? Inaccuracy on a typical K-type thermocouple is the difference between hyperthermia and hypothermia!
It's a great idea, I just hadn't thought of it.
Offline macboy
« Reply #177 on: May 26, 2016, 04:05:45 pm »
rs20 is right, it's a terrible idea.
Typical inaccuracy on a multimeter thermocouple is terrible, relatively speaking. We are talking +/- several degrees at any temperature. If you are measuring your soldering iron tip temperature, maybe that's not too bad. If you are checking human body temperature for a fever, it is not acceptable in the least.  OTOH, when done right, with a proper ice-water (or triple point) bath for the cold junction and a giant lookup table or high order polynomial calculations for the mV-temp conversion, then you can get very high absolute accuracy from a thermocouple. A handheld meter doesn't do that. It uses a thermistor to estimate the cold junction temperature (or worse, skips it and just assumes room temp), and probably uses linear interpolation on a conversion table with a few points spread over the several hundred degree range of the thing.
Offline iXod
« Reply #178 on: May 29, 2016, 07:02:51 am »
I have 639 people on the multimeter signup list:
Where does one sign up for the multimeter list?
Is this for announcements re. order status and shipping?
Thanks.
« Reply #179 on: May 29, 2016, 07:23:59 am »
Thanks.
Not in this forum but it's available from Daves store on the main EEVblog website:
http://www.eevblog.com/store/
Avid Rabid Hobbyist
Offline iXod
« Reply #180 on: May 29, 2016, 09:38:22 pm »
Don't see where to sign up. Link to sign-up page?
« Reply #181 on: May 29, 2016, 10:38:13 pm »
I'm pretty sure Dave meant: signed up to buy.
Avid Rabid Hobbyist
Offline iXod
« Reply #182 on: May 29, 2016, 11:30:42 pm »
468 people have signed up to be notified when the meter is back in stock  :o
Will be interesting to see how many of those actually buy once they get the notification.
"...once they get the notification."
Apparently a sign-up list somewhere...
Offline iXod
« Reply #183 on: May 30, 2016, 02:01:17 am »
3. Banana plug adapters.  Hmmm....  These get used more frequently than I would have expected - and they make for a solid, convenient connection.  But they are small and easily lost, so I came up with this little idea - and it's been working well....
Sounds like you need a case:
http://www.fluke.com/fluke/inen/accessories/Cases-Holsters/CAMO-C25.htm?PID=78334
A pouch inside the zippered cover to accommodate misc bits.
Offline Hexureus
  • Country: pt
« Reply #184 on: January 17, 2017, 05:00:00 pm »
Hi Dave.
Are you ordering more multimeter?
I would like to buy one.
Thank's
Offline Russ
« Reply #185 on: November 18, 2017, 03:05:52 am »
I just received mine. Looks to be well designed and made. Looking forward to giving it a test spin. 👍
