Author Topic: Eevblog -Bryman DMM question  (Read 1431 times)
Offline RussTopic starter
« on: November 18, 2017, 01:29:14 am »
Hello
   I just received my EEVBLOG-Bryman DMM. Looks to be a nice unit. However, what is that little magnetic string holder for, how does it work?
Thanks
Offline iainwhite
  • Measure twice...
Re: Eevblog -Bryman DMM question
« Reply #1 on: November 18, 2017, 05:58:28 pm »
It slides into the back of the blue holster to act as a hanger or mag-mount.   If you can't work it out, I can post a couple photos to help.
The following users thanked this post: Mr. Scram
« Reply #2 on: November 18, 2017, 07:01:50 pm »
Ian
That would be great.
Thank you
Russ
« Reply #3 on: November 18, 2017, 07:09:02 pm »
Ian
   I figured it out. I was overthinking it 😬. Not the snuggest Of fits. It does not fall out?
Thanks
Russ
Offline iainwhite
  • Measure twice...
« Reply #4 on: November 18, 2017, 08:48:43 pm »
Russ,
See photo for how I attached mine.   The raised tab on the holster retains the underside of the hanger once it is pushed in.
Iain
« Reply #5 on: November 18, 2017, 09:01:59 pm »
Ian
    Thank you. I figured it out. I was overthinking it. Is it a snug enough fit to prevent it from falling out? How do you like the Meter? I just received mine.
Russ
Offline iainwhite
  • Measure twice...
« Reply #6 on: November 18, 2017, 09:14:40 pm »
It seems snug enough to me.  I tend not to use the hanger all that much, but it seems fine when I do. The magnetic mount works fine stuck to a vertical surface like a filing cabinet.
Main reason for buying was to support Dave, but it is also a really nice meter to use.   I am hoping to buy it's big brother (EEV 121GW) soon!
« Reply #7 on: November 18, 2017, 09:16:08 pm »
