Generally with power supply decoupling caps you can always go up to the next value with very low chance of bad side effects. I just consolidated some values that were low and close together so as to reduce the getting of many values. Higher voltage as well, as they will still be smaller than original, but the voltage derating will improve life. Modern units are a lot better than the originals size wise, generally they will fit.
