I've used them but I'm not a fan of them. They all use a very loose fit thread and they always have intermittent connections and in fact, the threads are so loose that the tips fall off and are easily lost. Frankly, the press on tips work better than the screw on ones. Someone, I don't remember who, also makes a set of meter probes that have a collar than you have to pull back to release or to add a tip (like a quick disconnect on an air line), they also work well and won't fall off.
