Author Topic: FA-95 miniature drive belt for Wayne Kerr SR268 Source  (Read 1609 times)
Offline pamphonicaTopic starter
« on: May 23, 2018, 06:31:51 pm »
I need a "PIC FA-95" miniature belt to complete the restoration of my Wayne Kerr SR268 Bridge source.
The belt in my SR268 has completely disintegrated, except for a small portion which amazingly has the belt type printed on it. It drives the switch for the many range lamps.
I can find the PIC Design website and the actual belt.  It's in their "No-Slip" series.  But they quote 96 days lead-time (apart from the extra $20 handling charge for a small order).
The belt is not a conventional ribbed one, but has pins sticking out sideways from a central core, a bit like a fishbone. The belt is 9.327" long and has 95 drive pins.
(See attachment for details)
A long shot but does anyone know where else I could get one of these belts, or something similar?
many thanks
Jeremy
(UK)
Offline Gregg
Re: FA-95 miniature drive belt for Wayne Kerr SR268 Source
« Reply #1 on: May 23, 2018, 07:15:46 pm »
Wm Berg makes this type of thing in the US.
http://www.wmberg.com/products/belts-and-chains
It may get you started looking in a new direction
« Reply #2 on: May 23, 2018, 09:27:42 pm »
Good suggestion.  Only a shame that their minimum order is $500!
I’ll try more searches with their part number.
I see that these belts can actually be cut to length and joined on site so I could just look for a large belt and see if I can modify it.
Offline texaspyro
« Reply #3 on: May 24, 2018, 05:52:54 am »
Try Stock Drive Products...
« Reply #4 on: May 25, 2018, 11:42:26 am »
A very good idea!  I checked and they seem to have what I want, at $15.10 a belt ($30 min order or $10 surcharge), so that little belt's going to be quite expensive by the time it finally gets to the UK.  I may try to see if a US friend can bring it over in August, to save a bit.
By the way, that's the belt with a steel core.  The original had an Aramid core and is out of stock.
thanks
Jeremy
« Last Edit: May 25, 2018, 11:52:46 am by pamphonica »
Offline konczm123
  • Country: hu
« Reply #5 on: June 19, 2018, 08:05:04 pm »
Could you give me the exact part number? Have you tried your part bought from  Stock Drive Products?
Thanks and regards,
Miklos
