Author Topic: Feeltech FY6800 60Mhz Function Generator frequency calibration  (Read 6176 times)
Offline cemelecTopic starter
Hi, has anyone managed to calibrate the new fy6800 frequency?
I have one of these and also the older FY6600 - I successfully calibrated the 6600 using the method outlined by Val - « Reply #805 on: February 23, 2018, 08:38:20 am »
but it does not seem to work with the FY6800
The procedure works, the frequency is corrected, but on power down then reboot the new settings are lost and the old frequency is output
Oddly if I repeat the procedure the modified frequency shows under "SYS", "More" but the actual output remains uncalibrated.
Anyone had any luck?
Thanks, Charles
Offline Mozee
Re: Feeltech FY6800 60Mhz Function Generator frequency calibration
« Reply #1 on: June 28, 2018, 10:05:52 pm »
I've got one as well and I see that the frequency is a little bit off .. also the amplitude voltage as well as the offset is not as shown on the display!
how did you calibrate yours?
We always learn, till the moment we’re dying , we learn how it feels to be dead
« Reply #2 on: June 30, 2018, 04:48:37 am »
That's the point - I can't calibrate the FY6800.  I can calibrate the FY6600 frequency but using the same procedure doesn't seem to work
Offline Mozee
« Reply #3 on: July 02, 2018, 03:08:24 pm »
ahha ok. but could you please direct me to the method cant seem to find it :(
Offline Mozee
« Reply #4 on: July 02, 2018, 04:23:15 pm »
Ok I found it but I don't seem to understand what frequency is to be set.
when I enter the calibration mode and the oscillator indicates 10MHZ I connected my ch1 to the oscilloscope and using the  counter function it indicated about 60MHZ (60000025 Hz ) so should I set the 10MHz in the FY6800 to  the exact frequency measure by the counter?
thank you
Offline Miti
« Reply #5 on: July 03, 2018, 11:31:51 pm »
thank you
I have an FY6600 Ver 3.3 and this is the procedure that worked for me:
1. Enter the calibration mode by pressing and holding STBY button and CH1 at power up
2. Set CH1 frequency to 10MHz
3. Go to the adjustment menu (SYSTEM, MORE, OSC)
3. Move the cursor to the right to reduce the frequency step
4. Adjust the frequency until your frequency counter reading is 10MHz
5. Long press the encoder to save the new setting. In your case is probably the OK button
I bet you know already, the oscilloscope is not an accurate frequency counter by any mean, not enough to do frequency calibration anyway.
Fear does not stop death, it stops life.
The following users thanked this post: Jacon, MUDGEL, Johnny B Good
Offline ArthurDent
« Reply #6 on: July 20, 2018, 11:12:51 pm »
On my FY6600 I replaced the not so great 50Mhz oscillator with a x5 PLL chip and added a OCXO and switch so I can use either the internal high accuracy 10Mhz OCXO or feed an external 10Mhz in from my GPS standard.
To check the output frequency I feed the signal from the FY6600 to my scope that is triggered from my GPS standard and watch for drift at 2ns/div.
The following users thanked this post: harrimansat, Jacon, MUDGEL
« Reply #7 on: August 19, 2018, 10:22:09 am »
For anyone still interested in this thread, the latest FY6800 firmware - version 1.7 - seems to fix my original problem.  On power down the FY6800 remembers the new calibration value, at least for now, havn't tried long term.
Offline janjor
« Reply #8 on: September 06, 2020, 06:57:58 pm »
Dear Mr. DenT, although I reaLISE THAT YOUR POST CONCERNING THE REPLACEMENT OF  THE fy6800 OSCILLATOR BY AN ocxo IS TWO YEARS OLD BY NOW, I ONLY RECENTLY CAME ACROSS THE PROBLEM OF THE RELATIVELY INSTABLE OSCILLATOR IN THE fy6800, SINCE I BOUGHT ONE ONLY TWO MONTHS AGO. COULD YOU PLEASE INFORM ME HOW YOU MANAGED TO DO THIS REPLACEMENT? ALSO, WOULDN'T IT BE EASIER TO REPLACE THE OSCILLATOR BY A 50 MhZ OCXO INSTEAD OF ADDING A 5X PLL? THANK YOU FOR YOUR HELP IN THIS MATTER,
JAN JOR
Offline ArthurDent
« Reply #9 on: September 06, 2020, 07:30:25 pm »
Jan Jor - There aren't a lot of good 50Mhz oscillators out there and you will have a much harder time calibrating them. 10Mhz is a universal standard frequency and you can get that from a GPSDO with great accuracy. I felt that if I'm going to make the time base in the FY6600 more accurate I might as well use an inexpensive high stability 10Mhz OCXO and also have it set up so I could use an external 10Mhz from a GPSDO if I didn't want to wait for internal OCXO to warm up. This modification took care of stabilizing the time base and the simple 5X PLL converted this 10Mhz standard frequency to the 50Mhz the FY6600 needed. If you are just using the function generator for audio work or other non critical applications then the standard oscillator is more than adequate but if you want to make use of the setability of the frequency displayed then a more accurate time base is needed.
Offline Labrat101
  • Regular
  • Renovating Old Test Equipment & Calibration ..
« Reply #10 on: September 06, 2020, 08:03:02 pm »
Hi, has anyone managed to calibrate the new fy6800 frequency?    :-DD
Hi
I also have one of these FY68.. I also tried all the mods which help some what with
accurate . including OCXO and PLL .
And after many hours I ran a full test on the Cyclone chip which is a FAKE ...
 so the chances are that you will have this 4 / 6ns phase Offset error that is a fault
with the Cyclone.
No on the FY6800 its NOT Jitter its a phasing error with the cyclone itself .
 The external DAC's are low quality . There is also the Z miss match
but that's just the icing on the cake .
« Last Edit: September 06, 2020, 08:42:53 pm by Labrat101 »
"   All Started With A BIG Bang!! .  .   & Magic Smoke  ".
Offline mawyatt
« Reply #11 on: September 06, 2020, 10:00:27 pm »
I don't have a FY68 but thought have you tried  "Injection Locking" the 50MHz oscillator to the 10MHz reference source? If the 10MHz source is somewhat square-wave it will have significant odd harmonics and thus a strong 5th will be present, and a simple light coupling between the oscillators might be all that's required. Maybe try a 10~100pf capacitor in series with a 100~1K resistor connecting the outputs.
You can tell if they lock together by the monitoring each oscillator and see if they drift with respect to each other. Of course the 10MHz oscillator may end up getting locked to the 50MHz, which is what you don't want. If this happens then you will need a buffer on the 10MHz reference oscillator, a simple CMOS inverter (74AC04) should work.
Another way is to inject the reference oscillator signal thru a series RC as mentioned into the Ground or Vcc pin on the 50MHz oscillator. This usually will couple enough energy into the oscillator to cause it to injection lock. The Vcc pin may be more successful if the decoupling capacitors have a high ESR, which may be true on a cheap instrument where cost corners are cut.
Hope this helps,
Best,
Mike
« Last Edit: September 06, 2020, 10:14:01 pm by mawyatt »
~Wyatt Labs by Mike~
