Take an empty genuine BIC ballpoint with the cone shaped tip. Remove and discard ink tube and wash out ink from tip with WD40 or similar. Push brass part of tip out. Punch the tiny ball out from the brass part with a small hard pin from the inside. Rinse brass part with IPA. *Either* dip a needle in conc. copper sulphate solution to flash plate it with copper so its easily solderable, then when there's enough copper on it, rinse with water then IPA *or* get a gold plated needle. Solder in place in the brass part of the tip with a few mm protruding. Reinstall in plastic part of the tip. Drill the end plug at the top of the body to suit the test lead wire, thread it through and solder to the eye of the needle. Reassemble and use BIC cap to guard the point while its in your toolbag.
I wouldn't care to use such a probe at greater than SELV voltages, but for low voltage work its quite usable and if you need a thin sharp probe that can access an individual QFN package pin, its about the cheapest that's effective.
