Poll
164 (24.3%)
327 (48.4%)
33 (4.9%)
27 (4%)
125 (18.5%)
Total Members Voted: 593
Author Topic: Flir E4 Thermal imaging camera teardown  (Read 847502 times)
Radio-Jim, OrBy, stefbeer and 10 Guests are viewing this topic.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #495 on: November 03, 2013, 10:33:54 AM »
I'm fairly sure you can do it by putting the rndis.rsc file in \flashfs\system\appcore.d\factory.d
This file is in one of the early hack zips.
with rndis the only thing you can't do is webcam mode - you can pull your saved images via the Flir toolbar thing, or FTP
There is a
zlast_RNDIS.rsc in the firmware file for the FLIR iX series firmware. Could you just rename that file, or is the real RNDIS.rsc different?
Attatched are .rsc files for normal and rndis.
I'm not sure what happens if you have both - my best guess is they are read alphabetically, so to do rndis without touching the existing usb.rsc you may need to rename it to something later alphabetically.
(This may explain the  zlast name above)
The files are CR32'd, so can't just be edited without re-CRCing (method a few pages earlier here)
I did try making one that did all 3 protocols but it went a bit nuts..
BTW a reminder that the first thing you should probably to if playing is run RNDIS and use filezilla to ftp off a backup copy of the whole \flashfs structure, as this is all the data specific to your camera.
« Last Edit: November 03, 2013, 10:47:22 AM by mikeselectricstuff »
Mike's Electric Stuff: High voltage, vintage electronics, electrical curiosities
Day Job: UFOs, LEDs etc.
Versatronics & other low-end pick & place forum
Online Wann
  • Mechanical engineer gone rogue
« Reply #496 on: November 03, 2013, 10:40:50 AM »
So the zlast_RNDIS.rsc from the iX firmware file:
# USB mode MSD
.system entry
.system.usbmode text "RNDIS"
# CRC32 d51f0c78
and the rndis.rsc you zipped:
# Generated at 2000-01-08 21:43:17
# ID
.system entry
.system.usbmode text "UVC_MSD"
# CRC32 c37005c3
Hmm... That's the same as the usb.rsc you zipped...?
« Last Edit: November 03, 2013, 10:47:48 AM by Wann »
« Reply #497 on: November 03, 2013, 10:48:43 AM »
Oops - just updated zip file in above post with correct version
# USB mode MSD
.system entry
# CRC32 d51f0c78
Online Wann
« Reply #498 on: November 03, 2013, 11:00:17 AM »
Ahh. That makes sense.
So does the CRC checks the filename, or is removing "zlast_" via camera.cmd a possibility  :-/O
I've never worked with CRC before :-BROKE
Online Wann
« Reply #499 on: November 03, 2013, 11:01:22 AM »
Nooooo. It's the same CRC32 value for both  ;D
« Reply #500 on: November 03, 2013, 11:04:00 AM »
No - it reads all files in the config.d for .cfg and factory.d for .rsc files
Each file must have a valid CRC otherwise it is ignored.
I'm assuming, but not 100% confirmed, that it reads files in alphabetical order, and options in later files override any in earlier files.
.rsc files have CRC32 and are portable between units
.cfg files have CRC01 and include the unit serial number and so are specific to a particular camera.
« Last Edit: November 03, 2013, 11:06:28 AM by mikeselectricstuff »
Online Wann
« Reply #501 on: November 03, 2013, 11:15:30 AM »
So the rndis.rsc you showed has the CRC32:
# CRC32 d51f0c78
and the zlast_RNDIS.rsc from the iX firmware file:
# CRC32 d51f0c78
That must mean  :-/O on the filename  :-//
Any brave volunteer with an i3?
« Last Edit: November 03, 2013, 11:17:51 AM by Wann »
« Reply #502 on: November 03, 2013, 11:20:24 AM »
Actually I vaguely recall that the  i3 already has a known way to do rndis from the keypad - take a look a few pages back.
Online Wann
« Reply #503 on: November 03, 2013, 11:23:54 AM »
Yes you're right.
Offline olsenn
« Reply #504 on: November 03, 2013, 12:22:16 PM »
Can someone post a screenshot from the E4 (prior to applying the hack) and the same shot after the hack has been applied? I'd like to see the difference an increase in resolution makes.
Also, since I noticed that there's been a lot of talk about firmware and crc checks etc. has there been any new progress on this hack? I am under the impression that the E4 can now become an E8 without opening it up?
Online Wann
« Reply #505 on: November 03, 2013, 01:08:06 PM »
Maybe I can take some in the morning.
See post #524  :P
Offline nova1200
« Reply #506 on: November 03, 2013, 01:36:39 PM »
It works!! Fantastic sleuthing everyone!
Here is a pair of images, not quite from the same perspective, but close. Before:
After:
This was on a just-purchased E4 (another sales commission for Mike) with firmware 1.18.7.
Online kaz911
  • Country: ae
« Reply #507 on: November 03, 2013, 02:52:21 PM »
here is a link to the 1.18.7 firmware http://cdn.cloud.flir.se/swdownload/assets/cameradownload/flir_ex_pn639_v1.18.7_update_pack.zip
can someone test if you can downgrade? (Only do if you have the later firmware of course) :)
« Reply #508 on: November 03, 2013, 08:22:07 PM »
Earlier hack works 1.18.7 - latest hack uses same file - only difference is how the file gets there, so no reason to think it won't work.
Offline Zoltan von Negrow
  • Country: cz
« Reply #509 on: November 03, 2013, 09:29:49 PM »
At a PC command prompt, run
  CRC01 E8.cfg (on the edited file)
This will display a line in the form
# CRC01 xxxxxxxx
I canĀ“t make crc in cmd, how exactly i have to make this?
