Sound familiar? If you're interested, you will find the original post here:
Yes, but following are the differences in my DMM-issue, from that of Kean's:-
1. After lying idle for few weeks/month, when I took the Fluke-107 DMM to measure a low voltage circuit, it was only an intention, but not carried out. Because the Vdc reading was already reading erratically on switch ON, even without connecting probes anywhere, & even with shorting them. Also the previous instance of using DMM(weeks/month, ago) was sucessfull.
2. After the issue, I indeed disassembled it fully (
including rotary switch & LCD) & exposed bare PCB (
after some initial hesitatiton). There were no visible anamolies anywhere in PCB, including rotary contact pads, with naked eye & some lens magnification.
3. Priliminary testing of the front-end input protection components with another DMM confirmed, they are OK.
If you have watched my videos, you may be aware that I have seen parts that will check fine with the another meter but are still defective. There are other parts that make up the protection circuit beyond what you had listed and what was mentioned in the video I linked. ...
I agree.
The general thrust of your post/statements seems to indicate, that you still strongly believe that my DMM's problem or damage is due to a power transient, even though my statements are discounting that possibility. This I believe you are putting forth, based on your extensive experience with DMM's, especially fluke.
So let me put forth the following additional facts:-
I also tried to reverse engineer the front-end circuit, with limited success.
When PCB-traces went thru vias to the 3rd (middle) layer, and when I traced them to the top portion of PCB with crowded SMD components, I gave up, because of lack of adequate tools/infrastructure in my home-lab setup.
I have posted this partial front-end circuit earlier here in my
post#8 above, & reproduced below.
I am 100% sure that the main 3 protection components (Fusible resistor, PTC, & MOVs) are un-damaged & OK. These are not only tested by another DMM(AN8002) in resistance-mode, but with some extra rigged up circuitry from a bench PSU setup. Their values were returned correctly by AN8002, & ensured that the MOVs are not punched thru. The MOVs are taking 0.0 uA when 30V was applied to them. I did not want to subject 100's of volts to MOV's in insitu condition.
Since the PTC & MOV's are intact, they will protect the downstream elements to some extent. But I know there is still some unprotected path thru R51....
One other relevant point, in my problematic Fluke-107, when it is Vdc mode, across terminals there appears a significant DC voltage about 290mV, when measured by another DMM (AN8002).
Post #13. This indicates some current/voltage leaking into its front-end from some internal circuits. Can such a failure mode happen with a DMM failed with a power transient, in your opinion?
However I am prepared to follow your line of argument. Can u identify the device/devices which needs to be checked, as per your following quote?
I had read your posts and only saw where you had checked the one diode. I posted the video link showing where I had damaged a different one. These would have been the first thing I would have checked.
It is not very clear from your test video, which device you refer to. CR12 CR13 or any other?
