Author Topic: Fluke 29/79-2 and 87-3 Fuse Question  (Read 2110 times)
Offline ogdentoTopic starter
« on: May 22, 2018, 08:34:43 pm »
Hi folks,
I have Fluke 29, 79-2 and 87-3 meters... the 79-2 and 29 use the Bussman 1A and 15A fuses, whereas the 87-3 uses the Bussmann 0.44A and 11A fuses.
The 29/79-2 current ranges are 40mA and 10A, and the 87-3 ranges are 400mA and 10A.  I don't really understand why the 29/79-2 fuse specs are so much higher than the meter ranges allow, but that's getting off topic.
Newark, Digikey, etc sell 5-packs of Fluke fuses... is there any safety hazard in using the 87-3 spec'd fuses (0.44A and 11A) in the 29/79-2?
I did see a Fluke note saying not to use the 15A 29/79-2 fuse in the 87-3 (which makes sense to me), but I couldn't come up with any reason the 87-3 fuses wouldn't be ok in the 29/79-2.
Thanks
Offline ModemHead
  • No user-serviceable parts inside.
    • Mr. ModemHead
Re: Fluke 29/79-2 and 87-3 Fuse Question
« Reply #1 on: May 27, 2018, 03:23:04 pm »
The 11A/0.44A fuses are kind of a defacto standard nowadays for multimeter fuses, so you're good there.  The specs for the 79/29-II meters allow for a 30-second overload of 20A on the 10A range.  The 11A fuse might blow in that situation, whereas the 15A wouldn't.  Other than that, and without diving into the spec sheets, I think it would be OK to sub the fuses.
Offline Fungus
« Reply #2 on: May 27, 2018, 03:57:09 pm »
Replacing with a lower breaking current should be OK.
« Reply #3 on: May 29, 2018, 06:22:57 pm »
awesome, thanks for the info guys.
ModemHead I can't tell you how many times I've checked out the awesome stuff you've done with Flukes... love your site!
The following users thanked this post: ModemHead
