Author Topic: Fluke 45 calibration help  (Read 2875 times)
Offline DiracTopic starter
  • Country: pe
« on: January 03, 2017, 04:29:52 pm »
Hello good day. I bought a Fluke 45 Multimeter, when I performed the ohm test, put the tips together and the ohm 2.76 ohm was off, then download the service manual to calibrate and perform the calibration and continue the same at 2.76 ohm. Please if someone can help me with the zero ohm setting. I leave the images there.
imagen 2.76 ohm
imagen de la calibracion 290ohm
I would appreciate.
Offline oois1
  • Country: sg
Re: Fluke 45 calibration help
« Reply #1 on: July 28, 2017, 03:44:43 am »
I got the same problem too.
