Hi
I am using my Fluke 87V from past two years without any problem.I recently bought some solid smd tantalum caps & while testing the value,i found something weird...
These are 10uF tantalum smd caps(case - A/3216/1206).This is the link for the capS -
https://www.sunrom.com/p/10uf-25v-tantalum.The problem is ,whenever i am testing the caps(I bought two of them),the fluke is showing nearly 4.66uF.
But for all the other caps(Electrolytic/MLCC/Polyester/Normal Tantalum) I am testing,Fluke is returning proper value within spec.I also took image of the caps & zoom them & found that they are rated for 10uF.(I suspected that 4.7uF sent instead of 10uF).
What can be the cause?
