Yeah I understand that.. maybe I expressed myself wrong... is when you try and compare similar featured test equipment that the Fluke's usually command a certain premium.
On a checkbox-feature list, maybe.
But ... a month ago who would have suspected the reason that Fluke carefully takes all the PCB vias away from the switch contacts on their PCBs?
Let's compare a typical multimeter (vias in the tracks) with a Fluke 17B+ (where all the vias are moved off to the side).
Fluke obviously does that for a reason but can you guess why?
It appears that those vias cause friction, create resistance in the switch contact and shorten the life of the meter. That picture shows the 17B+
after the switch has been turned 50,000 times (the ZT101 above is brand new).
Compare it to the ZT101 after 50,000 turns:
Question: Which of those two meters is overpriced?
(and what other tricks does Fluke know when it comes to building reliable multimeters)
Flukes also have those precision laser trimmed resistors in them for stability and long life, etc. Those things are expensive, you won't find them in cheapo meters.
