Thanks for the help so far. I have tried to draw a circle by putting the cope into xy mode and putting 2 1kHz sine waves with a 90 degree phase difference into the inputs, the output is definitely not a circle. I have attached pictures. I have also tried to check for ripple on the supply voltages, the 5, 12 and-12V rails appear smooth but when looking at the schematics it looks like the x amplifier is powered by the 150V rail, and i cant test this with my DSO nano because the maximum voltage is about 80Vpp, Thanks
