I recently purchased a hantek dso5072p 70mhz scope. Picked up the required items to gain access to uart and a usb drive. Followed the directions exactly and no matter what I do or how many times I do it, or reboot it after doing it, or chmod ing the files so the scope can not change them it appears as a dso5072p in the menu every single time. I decided to update to latest firmware from hantek and rinse and repeat to same results. If it matters I've been able to turn the knob to 2ns even the day I pulled it out of the box.
Another thing I caught in the console and I'm not sure if it is relevant is:
[root@Hantek ~]# reboot
[root@Hantek ~]# umount: tmpfs busy - remounted read-only
umount: can't remount ubi0:rootfs read-only
umount: can't remount rootfs read-only
The system is going down NOW!
watchdog: S3C2410 Watchdog: watchdog did not stop!
Sent SIGTERM to all processes
Sent SIGKILL to all processes
Requesting system reboot
?OM*** Warning - bad CRC, using default environment
##### EmbedSky BIOS for SKY2416/TQ2416 #####
This Board: SDRAM is 64MB; Press Space key to Download Mode.!
NAND read: device 0 offset 0x380000, size 0x800
2048 bytes read: OK
**************************normal start*******************************
NAND erase: device 0 offset 0x380000, size 0x80000
Erasing at 0x3e0000 -- 100% complete.
OK
NAND write: device 0 offset 0x380000, size 0x800
Writing data at 0x380800 -- 100% complete.
2048 bytes written: OK
2048 bytes read: OK
Saving Environment to NAND...
Erasing Nand...
Warning: Erase size 0x00004000 smaller than one erase block 0x00020000
Erasing 0x00020000 instead
Erasing at 0x80000 -- 100% complete.
Writing to Nand... done
NAND read: device 0 offset 0x400000, size 0x400000
4194304 bytes read: OK
Boot with zImage
Starting kernel ...
Another thing worth mentioning. I've never had a bootscreen with my model number. I get a square qr code with hantek typed out, and then the second screen hantek your testing solution then im in the scope running
sw version 3.40.0 (170714.0)
serial ended in 8069
lcd.front.ts 3.3.0
If anyone could help me out that would be great.
