Author Topic: Have you seen a meter this low end before?  (Read 2769 times)
Offline jayjr1105Topic starter
« on: February 15, 2018, 09:33:37 pm »
Pro'sKit meter that came with my new Telephone Butt Set for work.  Laughable, however one of the nicest green backlights I've ever seen...
Offline Fungus
Re: Have you seen a meter this low end before?
« Reply #1 on: February 15, 2018, 11:41:23 pm »
Want!
Offline 0xdeadbeef
« Reply #2 on: February 15, 2018, 11:49:33 pm »
A 200mA current range?
Wow. Just wow.
Offline lowimpedance
  • Watts in an ohm?
« Reply #3 on: February 16, 2018, 12:00:26 am »
 At least its fused... :P  , even if its the wrong size for the clips. And I guess it doesn't pretend to be anything else ..!.
The croc clips would be worth more  :-DD.
Offline Muxr
« Reply #4 on: February 16, 2018, 12:02:29 am »
You have to admire the simplicity though. It doesn't pretend to be a proper DMM.. it just is what it is. I like it.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #5 on: February 16, 2018, 12:16:12 am »
Two inputs to help with A/V screwups
Nice backlight
Does not try to BS with fake CAT ratings
Very compact
Quite admirable.
Offline Holes Flow
« Reply #6 on: February 16, 2018, 12:18:24 am »
What struck me was, "Why have a selection switch when you have separate leads plugs? :)
Online joeqsmith
« Reply #7 on: February 16, 2018, 12:22:23 am »
For the on/off function and it makes it look more like a typical meter.
No CAT rating and no CE mark.  Wish we saw more realist markings like this.
Offline N0NB
  • Amateur radio op; electronics dabbler
    • N0NB.us
« Reply #8 on: February 16, 2018, 01:31:39 am »
Considering it is included for telephone work, it's probably only intended to measure talk battery on lines, nominally -48VDC.  Surprising that there isn't an AC range to measure ringing voltage which is typically 100VAC.  The 200mA range is likely intended for measuring the current draw of a "standard" telephone instrument which, as I recall, was around 60mA DC.
For the occasional work with POTS (Plain Old Telephone Service) circuits, the meter combined with the butt set will allow quite a bit of troubleshooting.
- Nate
The optimist proclaims we live in the best of all possible worlds.  The pessimist fears this is true.
Offline Fungus
« Reply #9 on: February 19, 2018, 09:04:25 am »
Wow. Just wow.
Nothing wrong with that.
I own meters with a 200mA range, it's probably do to the number of counts and the fact that the next step up would be 2 amps.
I looked on their web site and they don't seem to sell it separately.
« Reply #10 on: February 19, 2018, 03:34:07 pm »
Wow. Just wow.
Yeah, it came in a kit. You can buy the kit and sell the butt set on eBay for likely the same price as the kit.
Sent from my Pixel using Tapatalk
« Reply #11 on: February 19, 2018, 04:00:45 pm »
Nice clear digits and fairly large given the size of the meter, surprised it doesn't have a continuity or resistance range though. I like the way that it does not even pretend to a proper multimeter though I'd like to have seen a warning on it somewhere about what ranges it was for.
Offline Fungus
« Reply #12 on: February 19, 2018, 04:12:05 pm »
It's obviously made for a very specific function. That's what makes it interesting.
It has a bigger brother:
But... not the same. :-//
« Last Edit: February 19, 2018, 04:15:18 pm by Fungus »
Offline Kalvin
  • Embedded SW/HW.
« Reply #13 on: February 19, 2018, 04:33:11 pm »
What chip inside? Wonder when we will see first EEPROM hacks / Relative and hold hacks / Temperature hack / Serial and wireless connection hacks. Will this beat Fluke? :)
« Last Edit: February 19, 2018, 04:35:05 pm by Kalvin »
Offline rsjsouza
  • Eternally curious
« Reply #14 on: February 19, 2018, 05:24:31 pm »
IMHO that belongs to a different league, though. The first one is more like a "tester", while this one's intention is to be a full DMM - and the CATIII 600V rating kinda spoils it for me (although I can't prove otherwise). It has its charms, though.
Offline IDEngineer
« Reply #15 on: February 19, 2018, 06:57:04 pm »
A 200mA current range? Wow. Just wow.
Nothing wrong with that. I own meters with a 200mA range, it's probably do to the number of counts and the fact that the next step up would be 2 amps.
I happen to have a genuine Fluke 16 DMM and it maxes out at 200uA (MICROamps) on AC and DC current.
Just depends on what the meter is intended to do. The one that is the topic of this thread clearly has a very narrow applications range!
