Author Topic: ITECH 8500+ Series (IT8511+/IT8512+/...) (also BK8500?) Serial (TTL) connection  (Read 4955 times)
Offline sequoiaTopic starter
It would seem ITECH 8500plus series DC electronic loads all have Serial interface (high end models have USB and/or RS-232 connectors) but cheaper models appear to have TTL level serial connector (DB9) that is labeled as "COM (TTL)".
Do these units support SCPI commands or is it some proprietary protocol? (User manual doesn't really say much)
Anyone found specs/pinouts for this connector?
I'd assume if its indeed TTL-level serial connector there would be also pin with Vcc output? That would allow wiring a TTL level Bluetooth serial adapter board to that connector and have nice "air gapped" connection to the device over Bluetooth...
Offline lux
i have a IT8511A+ and the protocol of the units is proprietary.
I use this code for python: https://github.com/mattvenn/it8512
You can find the pinout here: https://www.eevblog.com/forum/testgear/witch-dc-load-maynuo-9812-or-itech-8512a/
And a bluetooth serial adapter should work, here is an example for the maynuo units: https://www.eevblog.com/forum/testgear/electronic-load-difference-between-m9710-and-m9711/25/
Offline bingo600
I just ordered a 8500A+ (still in transit) , and considered making a DIY IF until i saw this one.
For 10$ i just ordered one.
http://www.ebay.com/itm/Tyco-Electronics-IT-E131-RS232-Communication-Cable-New-/201812099592
Apparently someone else also saw this , so no more left.
Ps: The pinout i posted in that thread is from a maynuo , i haven't gotten any confirmation that the ITECH is the same.
/Bingo
I probed the "COM (TTL)" port on a IT8511+, as labeling suggests its a serial port that uses TTL level signaling.
Pinout is as follows:
1 = Vcc (+5V)
2 = RX (TTL 3.3V) [load receives data on this pin]
3 = TX (TTL 3.3V) [load transmits data on this pin]
5 = GND
Since port supplies +5V, should be easy to hookup one of those cheap Bluetooth Serial (UART )modules to this port and power it from Pin 1.
The following users thanked this post: bingo600
Online TurboTom
1 = Vcc (+5V)
5 = GND
That's basically what I did (see here: https://www.eevblog.com/forum/testgear/maynuo-m9812-usb-to-serial-isolated-interface/msg1004163/#msg1004163), the only difference is I used a Wifi / UART module. Works a treat.
Cheers,
Tom
Offline bingo600
Neat trick.
I've used ESP-Link , but it looses chars at high speeds (115.200) due to no handshake signaling implemented yet  :(
I just got my IT8512a+ load today , still waiting for the cable.
/Bingo
« Last Edit: February 13, 2017, 07:01:13 pm by bingo600 »
Take it apart when you get it :)   Interesting to see if its fully isolated, etc...
Offline bingo600
Might do that , if there's no cal sticker on it.
/Bingo
Offline oh2hyt
  • I lurk mainly
Has anyone tried how many measurements per second you can get to PC from load?
