http://opalkelly.com/
Poll
Which meter should be ran to celebrate 2000 subscribers?
Dave's new 121GW
58 (55.8%)
Gossen Metrawatt (you pick)
14 (13.5%)
HIOKI DT4282
6 (5.8%)
Anything but UNI-T (you pick)
1 (1%)
Anything made by UNI-T (you pick)
7 (6.7%)
I think the Fluke 87V is really a good meter and want to see if a third one would be better
10 (9.6%)
This testing is pointless! Please STOP damaging these meters!
8 (7.7%)
Total Members Voted: 104
Author Topic: Handheld meter electrical robustness testing.  (Read 185507 times)
msliva, HKJ, gslick, tautech and 3 Guests are viewing this topic.
Online Vgkid
Re: Handheld meter electrical robustness testing.
« Reply #1200 on: March 17, 2017, 07:27:28 AM »
That RS shunt is by far the largest I have seen in a handheld.  I think this video is going to be a David vs Goliath story except David looses big time.    :-DD
Metrahit looks interesting...
It looks like it will go this way.
RS-760H/mm2000/UT61E....ZT102
This will be interesting. That ZT shunt might be good for a watt. If you measure the size/resistance, you can do some ebay shopping.
If you own any North Hills Electronics gear, message me.
Online joeqsmith
« Reply #1201 on: March 17, 2017, 01:48:52 PM »
The videos close to 30 minutes so far and I still have not damaged a shunt but not to worry..  :-DD
How electrically robust is your meter?? http://www.youtube.com/channel/UCsK99WXk9VhcghnAauTBsbg
Online joeqsmith
« Reply #1202 on: March 18, 2017, 10:28:17 AM »
Watched Dave's reviews of the Gossen power meter.  :--  No way I would spend over $1000 on a meter with a tacked on resistor.  Too bad, like some of the features.  Review was not too great.  Hardly turned the thing on.
Looked at various pictures of the internals of other Gossen products.  Some look like they were made in the 90's.
Now looking at the lower end Extra.  From the manual, they mention the KS30 for additional protection.  Search their site, nothing.   I would like to get the KS30 with it if I go this route but can't find anyone who carries it.   Time to send them an email.
The multimeters are protected against transient overvoltages of
up to 8 kV with wave-front durations of 1.2 ms and halftimes of
50 ?s in the voltage measuring range. If longer pulse durations are
expected, for example when conducting measurements at transformers
or motors, we recommend the use of our KS30 measuring
adapter. It provides protection against transient
overvoltages of up to 6 kV with wave-front durations of 10, and
halftimes of 1000 ?s.
Continuous load capacity is 1200 VRMS. Additional influence error
caused by the KS30 measuring adapter amounts to approximately
-2%.
Online joeqsmith
« Reply #1203 on: March 19, 2017, 03:40:03 PM »
The shunt testing is finished.  Was going to test the shunt out of the 121GW but the foam would not conduct.  And I thought it was the lowest burden meter out there.
Video should be up in the today sometime. (lack of sleep)
« Last Edit: March 19, 2017, 11:08:52 PM by joeqsmith »
Online Vgkid
« Reply #1204 on: March 19, 2017, 04:06:20 PM »
I'll be looking forward to it. I saw your post, and expected to see a video.
Is is just me, or do some of those shunts look different... :-BROKE >:D
Online joeqsmith
« Reply #1205 on: March 19, 2017, 11:19:22 PM »
Warning, its long.  12 shunts X 5 seconds per Ampere X (100A - 3A).  Even speeding this up, it's still about 45 minutes.  I ran some checks using nichrome wire as well.
The following users thanked this post: saturation, 3db
Online joeqsmith
« Reply #1206 on: March 20, 2017, 06:57:56 AM »
If all of the shunts were identical, there are still some errors in the setup.  Sensing the voltage near the supply for example adds some error, it will not vary like the temperature sensor placement or the biggest problem, inserting the shunts into the clamps.
To give you some idea of the variance of the jig, here is the plots showing the resistance across the entire 100 Ampere sweep for all of the 5mohm shunts.
Online joeqsmith
« Reply #1207 on: March 20, 2017, 07:12:53 AM »
Two of these shunts were from CEM branded meters.  They appear to have the same diameter and length so we expect these two will behave the same.   Only looking at these two, the first graph shows their resistance.  The next plot shows their voltage drop.  These two were very linear across the entire 100A sweep.   The temperatures were within 70deg C which is better than I would expect as there is a large temperature gradient across the surface.  Those clamps are a plated brass with lots of thermal mass.
One thing I wish I had explained was Watt density.  We are looking at the power dissipated with how much surface area the part has.  The Kunsuntest ZT102 and free HF meter both calculated out to 12W/in^2.  The nichrome with even higher resistance really pushes this up and why it makes good toasters and hair dryers. Lots of heat in a very small space..
Online joeqsmith
« Reply #1208 on: March 20, 2017, 07:16:15 AM »
For the few people that are interested, I have attached the raw data I collected during these tests.   Voltage, current, power and temperature.  One file for each shunt tested.
Online Vgkid
« Reply #1209 on: March 20, 2017, 07:19:52 AM »
I look forward to watching the video. Unfortunately at the earliest it will be Monday, or Tuesday night.
« Reply #1210 on: March 20, 2017, 07:30:30 AM »
In no way have I seen the insides of as many DMM's as Joe but in cheaper ones the shunts seem to be made of copper or brass.  :--
Unless they're made of materials accepted for shunts like Constantan, no wonder there's some variability.  ::)
Avid Rabid Hobbyist & NZ Siglent Distributor
Online joeqsmith
« Reply #1211 on: March 20, 2017, 07:49:36 AM »
Manganin is made up of about 86% copper, 12% manganese and nickel, so yes they do look like copper.   Constantan has about 55% copper and nickel.
https://books.google.com/books?id=sxkPJzmkhnUC&pg=PA158&lpg=PA158&dq=constantan+or+manganin&source=bl&ots=AJxv8bmzp-&sig=0FcOzbS9QGymOEuqr71AYjH5p8M&hl=en&sa=X&ved=0ahUKEwi_0uqOuOPSAhWm7YMKHcPjCREQ6AEIajAL
Online Vgkid
« Reply #1212 on: March 20, 2017, 05:36:21 PM »
Nice job, I enjoyed it.
What was the software you were using?
Online joeqsmith
« Reply #1213 on: March 20, 2017, 09:34:15 PM »
I use LabVIEW.
Voltage drop measures at 10.00 Amperes
Using large body HRC fuses
Brymen, BM869s, 312mV
UNI-T, UT61E, 239mV, Modified
CEM, DT9939, 350mV
UNI-T, UT181A, 294mV
Fluke, 115, 280mV
AMPROBE, AM530, 353mV
Fluke, 107, 325mV
Other...
Cen-Tech, 98025, 131mV, No fuse
External Shunt, 10mV
I made one more attempt to further improve the UT61E by adding even more copper and reduced it another 20mV was all.
« Last Edit: March 20, 2017, 10:16:14 PM by joeqsmith »
Online rsjsouza
    • Vbe - vídeo blog eletrônico
« Reply #1214 on: March 21, 2017, 05:39:55 AM »
Joe, one more excellent video. Thank you for the work.
I think that Centech will start stamping their meters with "exclusive 100A fuse" in the 10A input. That or the input will actually be marked as 100A (20 sec max).  ;D
Online bitseeker
« Reply #1215 on: March 21, 2017, 08:48:24 AM »
LOL, yeah. Instant upgrade of fuse and higher current rating. Weee!
Got GAS? Get relief at Test Equipment Anonymous. It's a TEA party.
Online joeqsmith
« Reply #1216 on: March 21, 2017, 10:33:28 AM »
Voltage drop of the meter test leads swept from 2 to 20 Amperes in 2A increments.   One meter stands alone....
Online Vgkid
« Reply #1217 on: March 21, 2017, 11:13:48 AM »
Is that Centech yellow/green?
Online joeqsmith
« Reply #1218 on: March 21, 2017, 01:46:42 PM »
You bet it is.  They could make the meter with 100A for a 20 seconds and if the shunt doesn't melt off the board, the leads would open.
I wonder how the probes included with the two Kasuntest meters would do.  Better yet, I wonder what leads the 121GW will include.
Online Vgkid
« Reply #1219 on: March 21, 2017, 02:37:38 PM »
You should have filmed that.
on the 1.21GW That will be a good guess.
I have a pair of Probemasters on my 87-1, and a set of modified(cut off safety shroud) gold Brymen's on the 3456A, with a set of Fluke probes floating around. My biggest problem with the HF meter, is that the probes are too short :( .
Online joeqsmith
« Reply #1220 on: March 22, 2017, 11:12:37 AM »
He mentioned they would start testing in January but I guess that was pushed out.  Better to make sure they are happy with it before it gets released.
I did capture the lead tests.  Here is the free cen-tech meter leads.
https://youtu.be/fQowDZstguw?t=1222
Online joeqsmith
« Reply #1221 on: March 24, 2017, 12:55:50 PM »
The UT61E, a real 20A meter.
Some calculations,  fuse & Manganin sheet stock
https://www.digikey.com/product-detail/en/schurter-inc/0090.0020/486-2707-ND/2644881
Online joeqsmith
« Reply #1222 on: March 24, 2017, 12:57:27 PM »
Current through the shunt, voltage across the shunt and calculated resistance compared with the original shunt.
Online joeqsmith
« Reply #1223 on: March 24, 2017, 12:59:19 PM »
Much lower Watt density.    Note also the added copper in the terminals.
Online joeqsmith
« Reply #1224 on: March 24, 2017, 01:00:59 PM »
Checking alignment against the Brymen BM869s.
